Thank you for the warning, I was going to try them next but I've seen a number of reviews just like yours. The search continues...
It's not. I do need a new one but it's a cost I'm putting off whilst I wait to see what happens with Brexit/Pandemic/Work.
Hi All, I live in the UK and I need a second number for my mobile for work (I don't want to hand out my personal number to clients). VOIP/Virtual...
Needles are lined up after a little manual fiddling (had to strip the instrument cluster again so I could get at the guages, remove them all,...
Thank you! This fixed the power steering issue but the battery had also had it (it had a warrenty for 3 years but it came with the car - which was...
Thank you RedFlames, that's so helpful!
I've been having some problems with my car (2009 Ford Focus Zetec 1.8L Petrol Manual - battery drains if it's not used for 48-72 hours) and did a...
Just passed my Comptia ITF+! I used a Udemy course (Mike Meyers), a udemy set of practice tests (not sure who made them) and lots of googling. I...
I just saw the Asus Tuff A15: [MEDIA] Thanks to better cooling and a bigger battery it outperforms the G14 in most tests despite a slower...
https://www.scan.co.uk/products/156-asus-tuf-gaming-a15-fa506iv-al032t-fhd-ips-144hz-ryzen-7-4800h-16gb-ddr4-1tb-nvme-6gb-rtx-2060-w See reviews...
I've been looking at a career change for a bit and I'm considering Cyber security but its a long term goal as my experience runs to: - building...
On the downside, received my redundancy paperwork this week. On the upside, the school may be bought by an investor from China. Deal is in the...
@RedFlames fair point. If they need to be routed in the walls then routing them will need to be moved up to item 2. If they only have to be moved...
Thanks @blackerthanblack that's reassuring and will save us quite a bit. We'll make sure someone is there to let them in. The one thing I'm...
We've finally got the money to buy and have found a place but its in a bit of a state as its been an abused rental property which has had no work...
Sadly I am not an experienced DIYer (computers, networking, mobile phone repair, rockets, high altitude balloons and custom electronics are no...
Thanks for the advice. Does anyone know a good cable thrower near Rugeley, West Midlands?
We're putting in an offer on a new place and I want to get cables run out of sight from the office, on one side of the house to a couple of other...
Get the popcorn, if the last ~100 days have seemed crazy this is about to get even more out of control:...
I've voted for this one. I loved the Red Arrows as a kid and had a couple of old Airfix models of the planes (never managed to get a cockpit on...
