This thing is an extra 130 dollars over the 2600k so your basically paying 130 for 100 mhz no thank you. I'd say just grab a 2600k instead.
I agree but I didn't buy my second 460 just for BF 3 my intention was to be able to max out Crysis and it did do that very well. I thought I would...
This just pissed me off. I bought a second GTX 460 and run them two 460's in sli so I could run this game maxed out with no problems but...
This forum has some benchies that were digged up http://forums.filefront.com/tech-discussion/367972-getting-new-video-card.html
Proformace price are looking good. however I was hoping they had a new featuer set for there 9xxxx line of cards
I'm going to save for that Geforce 8800 GT to play this game. I think the alcohol simulator will be cool, im really hoping they make a...
How do you guys think my pc will play in this game
No The 8600 GT is slower then you're 7800 GTX but the 8600 GTS is almost as fast.
Is there any way How I can find out what type of motherboard I have on my perbuild dell. Any suggestions?
Out of the 2 options go for the 7600 GT... But it will be well worth it to go for a 8600.
Go with a 7950 GT is you can its almost as fast as a 7900 GTX and with a little bit of ocing you can reach 79 GTX speeds no problem.
You're X1900XTX dosent have DX 10. But if you're buying a 8800 just for DX 10 then you might aswell wait for games that have DX 10 to come out...
The 6800xt supports HDR as well. But get the 7600 gt instead of the 6800.
Sounds sweet! It prolly will end up beating the 8800 GTX. hopfully it is dosent have 2 powerconnectors like the GTX has.
Try and get an X1800GTO.
Great! we'll finally see what the geforce 8800 is finally made out of.
The 8600 Ultra should smoke the X1950's. Like the past gens mid range nvidia> last gen High end ATI
lol Anyway I'm thinking the 80nm versions of the G80 is going to be the G81's or 8900's
Even if you do Overclock your 7800 GT to 7900 GS speeds the GS has a G71 core (an enhaanced version of the G70 aka 7800 GT) the GS will be a wee...
Yeah get the 7900GS Its such a sweet mid range card.
