Thanks for the help, I did get access to my old account back. Anyways, I'm not sure if this even matters, but I don't see the point in having two...
I wish you good luck, but I hope your unlocking and switching carrier experience was better than the one I had. I bought a motorola v360 OEM...
The question I would have is along the same lines as what hitman is getting to: Did you upgrade from the mx4000 to the 6600gt? While your...
I'm just posting this for being silly, but recently I got shocked in the ear from my cellphone headset. I unplugged it from my phone and for...
I'd be willing to bet that second product you linked is just some version of unsweetened toothpaste.
Netstatlive by analogx might fit the bill for you. You can download it here:...
Not what I'm looking for.
yousendit.com recently went to a pay service for larger file transfers from the looks of it. You can't send more than 100meg files without...
That is a cleaner, and doesn't appear to be anything of the sort of scratch repair.
Sorry man.
Most of the phones out nowadays do in fact use TFT screens, I'd feel fairly confident that they would not damage the screen. I would be hesitant...
Do they have the option of supplying you with a full version of windows, or without any operating system at all? With that kind of hardware...
That setting, which is unlikely for him to have enabled since it's not enabled by default, would have nothing to do with being in the safely...
I had a chance to try out the 820, a friend bought it and I was mostly curious about using it to play music through my cellphone and take a call...
You've overanalyzing things. What exactly is that second screen going to be DOING when you're playing a game? It's going to be doing NOTHING...
Why wouldnt you want to use the hide inactive tray icons? Do you not like the arrow? If that is the case, which I doubt it is not, consider...
The short answer to what I was going to tell you, is that operating systems are not hot-swappable with non-peripheral hardware. Non peripheral...
I love the situation personally. My mainboard came with 2 external SATA connectors, being able to use SATA devices the same way as flash drives,...
I recently sold an athlonxp 2500+ on ebay for $45. I sold an MSI K7N2Delta for 40 dollars, with two addin cards supporting firewire and sata....
Why not have your 7900 connected to both monitors? I've done that for ages now.
