The easiest way that I can think of doing what you want is to use an Arduino micro-controller. Basically its a prototyping micro-controller that...
Firstly heres what I have for a system: Macbook Pro with OS X Leopard with a 120GB hard drive. Heres what I want to do: Ive got a new 250GB hard...
did you use a regular CAT5e cable or a crossover cable? Correct me if Im wrong, but I think because youre not plugging into a router, you need a...
That was my initial thought...just thought Id check to be sure so thanks!:thumb:
Thats EXACTLY what Im going for lol. Yeah instead of going out an buying a linksys access point for like 70 bucks, Im trying to find out if its...
Ok so heres my situation: In my house we have several computers all networked together: two windows PCs and my Macbook pro. My mac and my desktop...
well in that case I would say that youve got some defective components on your hands here. Doesnt matter. If youre running a dual core processor...
well when you reset the CMOS did it work at all? My guess is that being that your ram is only 800MHz, it probably cant handle the over-clocking of...
Yup, definitely the way to go. Youve got a "legit" copy from a friend (still not as legit as actually buying leopard) so it makes it a tiny bit...
lol...whoopsy!!! Just noticed that youre in New Zealand :duh: hahaha. but anyway Comcast is an ISP here in the states that is being investigated...
XAMPP (apache, MySQL, PHP) + PHProxy :D (dont forget to open the necessary ports!!! the HTTP port is 80) and also putting it in a "misleading"...
if your bio wont post then I can think of 2 problems: 1) your ram has for some reason gone bad. This Im kinda uncertain on because as you said,...
Id say if youve got comcast they might be throttling it (correct me if thats wrong). Either that or theres a TON of people trying to download it...
first off, is this a mac with tiger on it that youre trying to upgrade to leopard and then put XP on or is it a windows PC with XP that you want...
Im not sure about the whole power issue...sounds like maybe some internal connection to either the power switch or the power jack is loose or...
Well first off this is my first time using final cut to put together a video that Im making. Heres my problem: I imported my video from my...
Yeah the one that Im looking to put on my external drive is final cut... :blah:
Alrighty, so I want to run some applications on my Macbook pro here (Running Leopard) on my external 500GB Firewire hard drive because my internal...
Ive got a Dell Dimension 3000 and Im trying to recover it to the factory defaults. It has a recovery ghost partition on it but there is no utility...
Haha..nope its there....its just REALLY small. Its down below the IRC Isles:p
