Discussion thread HERE. After a long hiatus from this project I got some free time to try and get closer to finishing up this mod. Although I...
I'll try that next go round. Thanks.
That's what I did. Needed a custom length and ran down to Home Depot and bought a couple of 4' rods of 6/32 and cut it to length. Used a Dremel to...
Hey! Long time no update! And guess what? STILL no update. Just waiting for some response for waterjet cut parts so I'm still hanging in...
Quick update. Got tired of waiting since I never heard back from and water/laser cutters for the final pieces I need done so I took a stab at...
Here's what up to date. I've been attempting to get ahold of ANYbody that can laser/waterjet cut some final pieces of aluminum for me and...
I must report that the HIper PSU is not a dog after all. I tested it and it is rock solid. Possibly it was something about the loss of amperage...
PICS!!! First off a quick look at how I got around the PNY's fan issue. [IMG][IMG] [IMG][IMG] As you can see I simply rigged an...
Well. The rig became totally unusable after my last post and needless to say that I was PISSED! I was trying to use the color picker in Photoshop...
Not so good news. The new PSU doesn't seem to be capable of running my 6800. I shut down the machine last night and when I restarted I got...
Project: Geared Up! Wuzzup! Decided to finally make the move to the new format. Original thread HERE. New worklog HERE . The project is...
Okay. Decided to get the PSU installed today. The thing that bothered me was that there was no LED lighting on this versio of Hiper's PSU's....
Okay! It's part of a coilover kit I bought years back and never got around to installing on my Prelude (I mod my car too). [IMG] It looks...
UPDATE TIME! Prepped the Hiper PSU prior to installing it in the case. [IMG] [IMG] [IMG] And swapped out the fan grills. I was going...
Okay. Small update. Got REAL tired of looking at that UGLY plastic panel on the "Innovadrive" so I decided to do something about it. The...
No real updates. Life is hectic just recently. Sorry. But I am entering the A.C. Ryan contest so wish me luck although I have VERY stiff...
Were the collets difficult to remove?
Here are some pics of the "Innovadrive". [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] And here it is installed and awaiting water. It's...
Well considering the Apex is supposed to be an EXTERNALLY MOUNTED kit I'm confused. I suppose if you got rid of the radbox then it would fit no...
Well I'm still relatively new to watercooling so this is all a big experiment for me. But seeing as how this is going into a seperate loop I'm not...
