so my vote would'va make some difference,but they didn't approve... i hope that they will consider the close result and decide to make both...
you're right,because if it makes only black owl all this time spend on this thread it will be a waste. what are the conditions to vote for...
do you really think that this is a problem ? (the fan noise) who is gonna buy this case will not think at the same problem as you do. if it where...
it's not a sure thing,there are not handpicked to know the performance.even if someone post a result it's not like if you have the same videocard...
i don't know why did you make this choice with the cooler....beats me.it-s good on a nehalem untill you reach 1.4v,after that it's a shitty...
for afterburner to work (unlock voltage feature) you have to modify the config file,to put UnlockVoltageControl=1 UnlockVoltageMonitoring=1 to...
in my ipinion you don't need a power supply bigger than 500w for your system from signature. if you plan to change your gpu,to make a sli...
Proteus is superb,a real replacement for Corsair 800Dw. everibody i showed this case project was WOW. +1 from me for Proteus and nothing else.
