480 at the moment on overclockers for the u2711, otherwise the 24 one is just as good
dell u2711, i have just ordered from oc or the hazro has comparable reviews
i would be most interested if you compared the playback on a ps3 and a Pc with this drive rather then the benchies. And maybe ease of use compared...
Wheres the sharkoon's, they been out for a while now and Bit havent reviewed them ? I have them and they are great, can you do a review and...
can the crew at bit-tech possibly review some 5.1 headphones, the sharkoon or the Tritton AX360 Pretty Please
i had a similar problem , the artefacts i had where like snow or black snow depending on the color but i just bought the card and so returned it
The philips 20 inch widescreen wasnt included either :( I think you should include the dell one as well, then it would be the best review on the web
i've ordered a Tagan 420w psu and i will post the results tommorow hopefully this psu will be slightly futureproof with a PCI graphic connector...
it did manage to beep when booting but still didnt detect any display, and the afterwards no beeps at all. when everything bar gfx card was...
thanks for the replies Yes i did plug it in , might try and remove everything apart from GFX card and see what happens.
Just a quick question, my brand new 7800gs arrived today an when plugged the pc wont make beep when booting or display anything. Is it likely to...
A couple of weeks i damaged my 6600gt when changing the fan to a zalman cooler i kinda rushed the job and used some cutting pliers to remove the 4...
I cant seem to find much info on the web at all. I have a philips 20inch widescreen monitor thats native resolution is 1680x1050 but through the...
Hi all I was fitting a zalman cooler to my card and when hastily removing the existing heatsink i think i damaged one of the ic's. Anyway not...
I moved over from ps2 to xbox360 and was well impressed with halo2 the gameplay and graphics are superb and the whn you do the live...
I've moved from sony ps2 and im well impressed with it so far. I'm loving PGR3 online and Halo 2(even with control pad) Soon buying COD 2 ,...
testing [IMG] Excellent got my tag working !! Thanks Now just need get better at PGR 3 and Halo2 (used to kb / mouse for FPS)
I moved from Ps2 to xbox and it a soo much better (all the live and integrated stuff you can do like live arcade, trailers and stuff) Im just...
Does anyone know anyone that sells in Krylon Fusion paint in the uk or that will ship to the uk. I have seen a few people use it but cant find...
check out this link its the best guide i have seen http://linear1.org/gm/archives/00000156.php
