no one? i found ultramon - it can disable the secondary display completely, even moving open windows to the primary display. but it doesnt...
hello! i just got some new hardware for my new rig. this is my first dual display rig. and also my first scratch build :) wish me luck! my...
hello! i wanted to know where i could find the dimensions for mobo rear panels.... i want to cut some plastic to fit into the rear of the...
@okapi: do you mean to say that there are no dual socketed motherboards for the pentium socket 775's?? Kingston is available here. i am...
time for a little update. i was running around the whole place getting prices for the mobo and the procs. very frankly, they are too high for...
i went to seagate with a 4 gb drive which had a 7 year warranty, after about 5.5 years of owning it. they said they didnt have a 4 gb drive on...
thank you for the replies! @oasked: i got leads to a dual redundant IBM PSU i dont have any info about them, but i'll get to see them...
hello! my old workstation died yesterday, an i am looking to buy a new system on monday or tuesday. i dont have enough liquid money right now,...
it may be your HDDs it is the only component in the system that rotates at a high enough speed to produce a squeeeeal! try this: remove all...
hello all! thank you all, for your thoughts. i just want to mention that cost is not a factor here, as i have the silver sitting in my...
hello all! thanks for all the replies! @cinnander: sad to say, i dont have a butler, and i dont fancy taking apart my computer every 2...
thank you! i cant afford the material! but i have a few kilos of heirloom silver - a set of utensils, but they were damaged in transit, so i...
hello! i know that copper is better than alluminium, when doing water blocks. but how is silver? 97% silver. pure silver is too soft to work...
hi! nice rig! can you please post a link or post the description / trade name of the mineral oil you are using? thanx, Ark!
disregarding all the pun and wise-cracks, i think you can try those NC based dyes. they can go into the matrix of the material and stay there....
hello all, i laid my paws on a LG CD burner, the GCE-8481B. i need some info. the drive is using a MT1518E controller, with an additional...
i think the fan's bearing is out. just add a minute quantity of silicon bearing grease (low viscosity grade), and see if the trouble persists....
i just wanted to ask, 99% of the time, there are anchor screws/bolts on the cover, securing the perpendicular alignment of the head carriage...
you were saying the acrylic was going cloudy?? were you using any kind of thinner / cleaner?? as it is, acrylic is soluble in many organic...
many thanx, i found one, that had a server and client system. so i used that and used VNC to switch on the server from the home. thank you. Ark!
