I might give it a try and post back... currently priming though.
Got bored yesterday, so I ran checked out the power consumption of my X3360 system for shits and giggles with my kill-a-watt. [img] Powered...
The GTS not only runs cooler, but doesn't heat up your case since it has a dual-slot HSF that exhausts out rather than inside the case. This is a...
I edited the first post switching the highest 400 MHz FSB run from 5:6 to 4:5 (960 MHz vs. 1,000 MHz) and included some info about subtimings to...
@chris - edited the 1st post to address your question.
About 7 months ago I posted data comparing two memory dividers (1:1 and 3:5 @ 333 MHz) on my then Q6600/P965 based system and concluded that for...
Version 1.6.1 is up. Totally re-wrote the section on memory which now includes a discussion on both DDR2/DDR3 and formulas you can use to...
thanks for the data... Actually, if you look at the other X2's in the table, 4-5 % increase is standard. Your's is 4.7 % so right in the mean :)
@badders - yeah, UAC sucks. It's a joke trying to emulate having to su in LINUX. It's more of a pain than it is a useful feature in my opinion....
The question you need to answer is: when will your next upgrade occur? If you're buying a new PC every few years, it's probably not a big deal,...
Dunno about that... most new games will take advantage of 4 cores over 2 cores. If you're buying the machine now and wanting to keep it for say...
...no takers?
Dunno about that... the following if from my overclocking guide:
+1 Why waste power and generate heat in your room? It does just take time.
+1 for jkdefrag and jkdefrag64 (for x64 o/s).
Well, guys I wrote up this procedure I used to minimize my vcores on my new x3360/P35-based system, and I thought I'd share it with folks. It's a...
Guide is now version 1.6 • Added a detailed section to help you find the minimum stable CPU and MB vcore settings. Check it out (near the...
Anyone with an X3360, can you please run the x264 Benchmark HD and either post the results here in this thread or simply PM them to me? Thanks!
+1 for p182. I love mine.
Dunno why all the bad press... XP Pro x64 with SP2 is a great OS. Driver support??? I haven't run into a problem at all. I too have 4 gigs of...
