When running Team Fortress 2, I keep getting a "Failed to create D3D device!" It was working fine two hours ago and now it does not work....
I like the compactness of this build. What CPU block are you using, and what fans are you using? Did you run cable sleeve over the water cooling...
I will have to keep that in mind. Thank you. :)
The inside of the case looks great. It has a very uniform blue / white glow. Could you please provide some details on the external radiator?
The varnish looks good. It adds to the rustic feel.
Very nice. Seeing that house makes me remember one of the reasons I want to return to Japan. What temps do you see when idling and under full...
What kind of covering if any are you going to place over the computer components?
What's wrong with a keyboard with no labeling? Also, that could be pretty expensive. The Das keyboard Ultimate has no labels and is around $130 USD.
Nice attention to detail. Very clean. Do you have any tips for measuring and bending the midplate?
Thank you very much. :) That is the game.
I can agree with Goodbytes about Dell. My first Dell laptop (2.0 GHz single core CPU) is five years old and still running, but my newer Dell...
Could you make this a bigger picture? I can't read all of what is circled.
I was reading a thread yesterday on bit-tech about a game, but the title slipped my mind and I forgot to bookmark it. :wallbash: All I remember...
Looks like this could turn out deadly. :thumb: I will be watching from my bunker. :lol:
What is the diameter of the hole on the top panel?
Damn, that reservoir ... :)
This looks nice. What are the dimensions of the case? What is the silver fitting with a red handle (I think) attached to the pump?
Sounds like a hard drive issue. This makes me more hesitant about recommending a Lenovo laptop now. :rolleyes:
Do you know what else is on the circuit that the computer is plugged into? I have heard of and dealt with a similar problem. A high output PSU on...
I overslept and when getting out of bed in a panic, hit my head on the nightstand. It hurt and now I have a bruise to add to my troubles. :sigh:
