You're right, I forgot that I plug my A/V cable from the LCD into an adapter. That is the exact cable I am using but the adapter goes from the...
Hi Baked, The cable I used doesn't look a lot like yours. Mine has the yellow, red and white connectors on one end, and on the other end has a...
Hehe, no worries on having the same name on the project. I've looked your project over and it's looking pretty good, so good luck with that. :thumb:
Hi BakedGoods, I'm useless with electronics too, so read this thread: edit: oops, wrong thread! This is the right one:...
It was very easy to do, which was good for me since I know virtually nothing about electronics. Like it says above, I just cut the cigarette...
I might not know what I'm taking about since I've only used TV out with my PSOne LCD, but on mine the brightness controls on the front can take it...
Ok, I see what you mean now. The adapter is meant to power the PSOne and the LCD together, but it works fine for just the screen. I had the...
All you need for S-Video is the right cable. There's a port on the back of the LCD that you plug it into, then plug the other end into the TV-out...
I'm not exactly sure what you mean. The cigarette adapter provides power to the LCD from your power supply once you mod it. For the image you need...
I bought the Impression version of this case and modded it. As far as I know it's identical to the gMono. I really doubt you could get a 120 in...
Pash91 - Yup, that's exactly what I did. Quick and easy and works great. I'm watching TV on the LCD right now :D
Thanks my58vw, I'm a big fan of your Divergence project. There are actually no reflections on the screen when I use the LCD. It might appear that...
www.samurize.com Very cool software, but it takes some work to get it configured the way you want.
I just couldn't leave well enough alone! I bought a PSOne LCD off Ebay for a good price, and proceeded to hack it up. I didn't have any room in...
lolzantz - all I did was chop the cigarette lighter end off and put a molex in its place. It was really easy and works well. fuz!on - you...
lolzantz - it was pretty simple. I just cut the cable like I indicated in the image a few posts back, then I stripped off some wire from the ends....
Thanks for all your help guys! The black wire turned out to be the 12V line. I spliced the molex onto the end of it, with the yellow going to the...
Thanks a lot Firehed, I'll do that. I can borrow a voltmeter tomorrow and test this out. Thanks everyone for the help! I'll update this and let...
The adapter converts the 12V line to 7.5V for the LCD to use. In order to demonstrate my electrical ignorance, I made a picture in Paint of how I...
Thanks for the info mrplow, I should have looked that up myself. What's the worst thing that could happen if I did hook this up wrong? The current...
