The Transcend SSD is mounted on a Sony floppy disk, it's a storage device on a storage device :) [IMG]
The interior, I had to swap the GTX 660 with a GTX 650 Ti, I had a major leak and the water went straight on the GTX 660, at the moment I am still...
Almost the final update - mounted the reservoir and now filling the loop :) Unfortunately one of my two Graphics Cards got water all over it so...
Update: The Power Supply is fitted to the rest of the system, the Antec HCP Platinum is one of the best :) , this one is the 850W variant. [IMG]
I know, but I don't trust adhesive, so screws for the trays especially for the motherboard tray.
Pretty much, the overall shape is based on the D-Frame Mini while the actual size of the case is more or less the size of the D-Frame. The dark...
What do you mean with the screws?
I'm glad you like it! I used spruce wood, I live in a mountain area so this wood was available :D
Update :D I mounted the motherboard and CPU block, and made a stand for the 240mm radiator using two square metal beams. [IMG] [IMG] [IMG]
Update: I finished installing all the trays for the Power Supply, pump and motherboard. [IMG] [IMG]
Update, I've been awake for most of the weekend, here is the finished project, I still have little things to do but I have to do the other project...
Here is a teaser of the project :) [IMG] Yes the bottle is not straight, it's a feature, if you know what I mean :D [IMG]
UPDATE! Here is the new reservoir for this project :D [IMG] Painted the cap, aka fitting plate :) [IMG] Labels removed and drilled the...
The GPU used on this project is a GTX 650 ti, the TwinFrozr III cooler matches the Titanium motherboard :) [IMG] Here is one amazing Power...
Update: Here is a teaser with the plexiglass :) [IMG] [IMG] [IMG] Stay tuned for more! :D
[IMG] Hi everyone, here is my first scratch build! The case is inspired by In Win's D-Frame Mini. I would like to thank my sponsors: In...
The PCI-e covers and paint photos will be done for tomorrow, but for now, here is the Alphacool heatgun, totally needed for hardtubing :) [IMG]...
The PCI-E covers and thumb screws are painted, tomorrow I will update on the paint used and upload more photos with these small parts. [IMG]
Download the GPU-Z app and run it, it will tell you everything about your GPU including frecuency, temperatures, TDP, Voltage and even ASIC...
Small PSU Update, two wires one pin and one sleeve :D [IMG]
