Here’s a timely video released overnight by Tech Jesus [MEDIA]
When I OC a CPU with an iGPU, I completely disable the iGPU and run from PCIE graphics. OCing a cpu requires more power. More power means more...
That OP has now left the forums, Jasper - hence shows up as Guest-xxxxx. If you're OC'ing your CPU to its limit, I personally wouldn't be using...
I did mean DHCP in the initial quote, my bad. OK, thanks for the explanation. I’ll leave my USG handling DHCP in that case. I’m not concerned...
Could you please explain, in what way is it better to have the Pi-Hole as the DNS server, other than you could then see per-IP blocks? The way I'm...
I've left my router as DHCP and from the router settings, set your pihole's IP as DNS. If you have an ISP supplied router, you may struggle with...
Interesting about Australia. I think our Govts aim is to deal with it in a similar fashion to seasonal flu after the initial vaccinations though,...
I don’t think that the Govt can or will make it de facto illegal to stop you doing certain things/refuse the jab because of National and...
Well, I would have thought that I wouldn’t need to add “within the bounds of law” to my statement but I fixed that for you: To be free is to have...
It really does depend upon how they see them being used/useful. If done badly, it could be a horrendous human rights inpedence. Private...
This trolling is getting boring now. I'm all for healthy discussion but can we please dial back the playground nonsense? It just makes people...
What happened with Sonos' backtrack on legacy product support in the end? Did they agree to continue to provide firmware for previous gen stuff?
What about the Bose Revolve? I have the larger Plus version which although portable, is on the larger side. You can buy a charging base as an...
Issues or queries with the forum are probably best placed in the Feedback & Suggestions sub-forum and just tag in one of the mods. If your...
What's the issue with it not having a dock? If you just want it for an alternative laptop audio solution, power it from the laptop's USB port and...
Thanks to everyone for the recommendations. Over the last 24hrs, the adlists and whitelist suggestions have increased the amount of blocked...
There's plenty of WiFi 6 equipment on the market already, so just double check when you settle on a brand/solution for your home. You can get...
It's always going to be a much better experience with a cabled up solution and then you can distribute your access points suitably around the...
Thank you very much! Those whitelists may be particularly useful for me too, so very much appreciated.
Ah ha! Right, I shall give that a go too then. Thanks for explaining that, as that's quite a big difference to what I previously understood (or...
