My SO I've had a lousy week hospital appointments and a few other bits and pieces so she scored two jobs lots. 1 from from Facebook marketplace...
so had the appointment 7 HOURS ROUND TRAVEL TIME - an hour waiting at the hospital - a 5minute bloody appointment that could have been done on a...
Dude I just checked your profile you're from Workington small world I'm in Maryport
The fact that I live in Cumbria and the doctor decided a while back that I need to see a neurosurgeon and the closest one is in Newcastle so on...
yeah I'll wait until the gpu prices drop aga1in and I've dropped almost every setting in the game to low or off doesn't seem to matter what the...
no idea it turned up in a box i plugged it in and turned it on default :)
I've not had a chance to watch the videos yet I'll do so later after some sleep Not sure about the ram speed but its set at whatever the default...
budget would be about £400 at the most
not sure on budget depends on what I need to spend with the market as crazy as it currently is I have no idea on what would be a reasonable budget...
HI all I'm not sure if this should be posted here or in the hardware section so I'll post here and if it needs to be moved hopefully a mod would...
[MEDIA] jump to 2.45
HI all I'm trying to run 4 monitors I have 2 GFX Cards 1.geforce gtx 1050 ti 2. is an old geforce 8400 gs the second monitor is only meant to...
I managed to find a picture showing the underneath of the keys if that helps for anyone to let me know if it would be cherry mx compatible [ATTACH]
No idea its literally a cheap 8 quid mini keyboard from ebay one of these [IMG]
I'm after some advice/help I'm planning on using a usb keypad as an extra keyboard along with HIDMACROS so that i can use it as a stream deck...
decided to try it anyway I'll post here if it works with pics :)
I was hoping something like this might work http://879cc5793edb3e59412e-75a72a3e9c7070cba3bb00450d808ff3.r7.cf5.rackcdn.com/00404001_4.jpg...
Hi all, I've recently got a curved monitor and want to add it to my monitor set up on a vesa triple arm mount. I want it if possible to go...
Yep, the argument is I've only got a single 128gGB NVME, AND a single 250GB ssd but I have 3 8TBS satas
I'm posting this here as I may have posted it in the wrong section the other day so hopefully second time around I'll get better results. okay, I...
