I'm pretty sure none of those are being made any more though, and I couldn't see any in stock in the first few places I looked. (Mind you, I'm...
If they'd announced this a couple of weeks ago I think I'd have assumed it was an April Fool. Still, if you need the absolute biggest radiator...
Ah, we're going back to Peltiers are we? Everything old is new again! Although I will admit that a fully warrantee'd all-in-one unit will be a...
Turns out that the Quadro does do everything I need (and it uses the full version of Aquasuite). Thanks for the recommendation!
Right, little update here. This week I've started to get some weird hangs in Windows, which I tracked down to anything that attempted to access my...
Huh, I hadn't realised that they were more than just a four-way fan extender. I'll have a closer look, because it does look like it might be just...
As someone who owns a lot of EK kit, but has been looking at Aquaeros recently (and wincing at the price), I'm interested.... I couldn't give a...
Just because someone says something you don't like, it doesn't mean it's bias or "intels ad dollars" (sic). If you read carefully they layout...
Well thats super impressive, but well out of my price range (and I'm happy with the 3700X I just bought thank very much), but the bit that made me...
Sometimes Windows will just decide to do that. It is possible to fix with a registry key, from the instructions on this page. However I followed...
Unless I turn on my Display Port monitor first, then my computer will only use the monitor plugged into the DVI port. Sometimes it's just easier...
Server 2012R2 (and up) has a technology called "Storage Tiers". Basically this is the software equivalent of a hybrid-SSD, you have a mixture of...
We were* using an Asus RT-AC66U with custom firmware from Merlin (Asus release the source for their firmware so it's a modification of that with...
As long as you download Win10 just before you reinstall it'll have all the updates included. And for software use Ninite, You just tick the boxes...
This is why I watercool, because the hardware is so damned sexy :)
If you only need to test things, then Microsoft offer a free download of a virtual machine for testing Internet Explorer. They have stopped...
Looks like they've got the lead actor sorted out... [IMG] ;)
I W/C my graphics card, but that makes me upgrade my GPU less, not more, because I have to add another £80-100 to the price of a GPU to cover the...
If you're after super fast, the Samsung PM961 drives are sweet! I picked up a 512GB one recently and it's basically faster than everything else in...
I had a check on one of the Draytek 2832's we have at work, and not only do they allow you to decide which WAN you want to use based on source (IP...
