This has been my go to router since launch and I have no real reason to move away from it. Rock solid performance and compatible with TomatoUSB....
My biggest gripe is how Uplay and Origin throw a hissy if you reformat but have a separate drive containing your games. Steam handles this very...
And for reference if anyone is wondering i store the below data in a 3 way parity storage space: 3.53 tb of data and it uses - 5.63tb of space...
This may or may not help you but there are a couple of powershell commands I have that have helped me in the past with Storage spaces: The below...
You can pickup pretty good quality ex corp T420's on Amazon for around £150-170. I've grabbed a couple for limited funds startups and they not...
Does anyone else not use power armor? I'm about 70 hours in, although I've hardly touched the main quest and bar one or two missions when I...
Its a bit off thread but I've been using a few free file backup programs recently. For simply backing up and versioning documents/files I've...
Hi All, I've just upgraded a machine to windows 10 and am using office 2013. I'm having trouble with Office warning "Some files may contain...
On some machines even when reviewing all windows updates and confirming that the update is not installed it still prompts. Hence why on some...
I've got to be honest the more it badgers me the less likely I am to upgrade. I force removed the update that pesters you and told it to be...
Amazon fire TV box. Managed to get it for £40 on an offer. Got kodi running on it and moved everything over to mysql. It replaces an ac Ryan HD...
I use PIA for streaming all the time when abroad and don't have any issues with buffering etc using iplayer / 4od.
Since you mention video editing you'd benefit from a quad. As such I'd recommend and i5 over the i3 or Pentium chips. You should also get more...
It really depends on what games you are trying to play. To get the smoothest performance out of the majority of newer games you are going to need...
Most ram is profiled to run with tighter timings when running at lower speeds. Something like CPU-Z can usually show you these. Heres a screenshot...
Was owed some time back from work so decided to put in some time to revisit Fallout New Vegas ahead of Fallout 4 being released. Had played it...
I've been using rsync for years ever since I started out with FreeNas. There is a windows app called DeltaCopy which you can use to allow rsync...
Can you not RMA it? I pulled the following from corsairs site (http://www.corsair.com/en-gb/support/warranty): AX Series™ PSUs have a 7...
Did you add any new hardware around that time? System Fans? PCI Cards? I've seen this on a couple of boards with certain cards in certain slots...
2133 @ 2133 with 9-10-9-27 1333 in server 800mhz in the media center Still got some 667 in an old laptop
