Thank you, faugusztin for your time. You've been very helpful. I appreciate your consideration.
Thank you, faugusztin for your reply. I am confused because Wikipedia says "To support higher-resolution display devices, the DVI specification...
I have an ACER Iconia W510 tablet with a micro HDMI socket and a monitor with a DVI-D input socket. I want to connect the tablet to the monitor....
Thank you, everyone, for your help. Much appreciated. Meanwhile I've found a website containing everything on NASes: http://www.smallnetbuilder.com/
Thank you, saspro and TaRkA DaHl for you replies. Would you recommend any NAS brand / model as I am a complete newbie in this field.
I am planning to put all data in one place, for backup purposes. The conditions are: minimum power consumption (MOST IMPORTANT) about 3 TB...
GoodBytes, thank you for your consideration and reply. Let me make it clear: let's exclude the laptop and focus on the replacement of slimline...
Hello everyone, I have a Packard Bell EASYNOTE E4710 laptop (bought in 2005). (Please do not send me links to their customer service). I...
Thank you, noizdaemon666 for your time to answer my question. Obviously the trades people advertise the theoretical values and it's the user's...
I bought a notebook Pavilion dv6-7025tx with Intel i7-3610QM processor, which has native USB 3.0 support. I attached an external disk Seagate...
Many thanks to all who replied. You've helped a lot.
Question about the Xeon family processors. 1. At http://newsroom.intel.com/docs/DOC-1963 Intel say that Xeon processors are for Entry-level...
Hello all, The optical drive NEC ND-6500A on my notebook Packard Bell EasyNote E4 manufactured Nov 2004 had to be replaced because of gradual...
Well, I don't know what 'Rep?' stands for, so I cannot reply. Anyway, this forum has been the most helpful of all I posted my problem at. Thank...
Thank you, saspro, Well, my problems have been solved. I am now trying the hardware monitor you suggested. It does not show any CPU...
Thank you for your consideration. Although the applications cannot detect a thermal sensor, the fan changes its speed accordingly; it is even...
I'm sorry for being lame on CPUs. You can see the details of the system above: CPU Type Mobile Intel Pentium M 710, 600 MHz (6 x 100) CPU...
Thank you so much for your suggestions. I have solved the problem. The BIOS has a switch, called Geyserville support, which has been disabled...
The hair dryer suggestion was an ironical rhetorical question. Of course I would never heat the CPU. No, the CPU is not overheated. Everything...
