I'm running an Acer Aspire Revo 3600. It has a 1.6Ghz Intel atom 230 single core processor and a Nvidia ION GPU. Currently my GPU is running at...
Thankyou SMC8788
can I get some proof that they are the same?
which is better? the ION yes?
I hate how it is the same PC, but they word it defferently. so its sill the atom ION?
Really need a speedy response to this. is http://www.ebuyer.com/product/167155 the same as...
bear in mind Grritsshawn that it is going to be running linux...
a £25 difference. and An extra 90GIG HDD space
Acer Revo 3600: single core processor 2GIG RAM vista or Acer Revo 3610: Duel core processor 2Gig RAM Win7 I'm only after it to play...
I'm looking at the 3600 with 160gig HDD and 2gig RAM. I want a pc to run uttorent non-stop, but also run XBMC, just .AVI's. The problem is that...
Has anyone got XBMC Live working well with an acer revo - 2gb RAM? If so, under what OS? Linux? Vista?
Hey guys, I am very interested in the Acer Revo... it seems brill, I plan to use as a HTPC. A lot of reviews say you have to have Vista and use a...
What do we think to - http://www.mini-itx.com/store/?c=44 Would loose me my PC build virginity too ;p
99.9% . AVI, But there has been one or two High Def files (.MKV?). Sorry, could you give an example of an Ion system?
OK, I'm after a PC to do the three following things: Play .AVI files through my TV via a VGA cable Run 24/7 on occasion torrenting Not use...
Once again, I really need your help? I bought a vista medion 8822 PC. and I want to restore it to its factory settings. There is a recovery...
Gun oil you day?Yes - got that! Lots of online threads say that WD-40 is the worst thing you can do - not good for the fan at all. Could this be true?
Ok, so here is a good question - What is the best oil to use to libe up those dusty PC fans? Hair clipper oil?
Yes, I suppose that you are right TheMusician. I will get the bigger, desktop PC and put my dream to loose my PC build virginity behind me... To...
