Can someone give me a max and min spec for the 12, 5, 3.3 voltage rails.. as i think mine are a bit out.. 13, 5.5, 3.3.. O.o
Hmm google does not come up with much... Anyway, system specs are as followed mobo: DFI lanparty UT 3200 ICFX T2R/G cpu: E8400 gpu: 4870...
You know how when the mic is quiet you use that mic boost in adv options under sound, well i can't get to it for some reason and hence my mic is...
the max power draw of these connections is 75 watt for the 6 pin and 150 for the 8 pin right? If so can someone answer why that is? p.s multi...
Well i think the card is screwed, as the card has a lot of play in the heatsink e.g you can move it alot Well anyway, running games like crysis...
MB: DFI lanparty ICFX3200-T2R/G ram: G-skill 4-4-4-12 800mhz CPU: E6600 GPU: ATI 3870 PSU: silverstone OP 1kw OS: windows XP sp2 Well each...
my card underload is at 80'c and games keep CTD alot of the time. idle is 50.. so to the point, what are ok temps for a 3870?? i am bit worried as...
As the tittle says, i want to try out teaming on my board but can't seem to find any info on how to do it. So to the point, does anyone here...
