And yes I've got the latest drivers. Can't swap out card or monitor as I've already sold them. Guess I'll just have to live with it.
Late reply, but I reinstalled Windows and the problem seems to have gone. I was due a fresh install anyway so just brought it forward. Still non...
Hi, I just bought an MSI GTX 270 and a 144Hz LG 24GM77 monitor. I have a weird issue and I don't know which of the two is causing it....
Thanks for clarifying that. Okay I'll connect with seperate cables. Cheers.
I've been given another XFX Radeon 5770 off a friend who has upgraded his pc. I've just installed it but I'm now worried about power supply....
No it runs down away from the MBO and sound card, through a hole at the back and tidied away neatly in the back of the case before coming out at...
Hi guys, I've received a pair of QPAD QH-90 headphones for Christmas and have a bit of an issue with my sound. Whenever I plug them into my...
Alright I'll check it out after work. Cheers for all your help.
What would I need to check about the wireless card?
Well I think he would still want enough storage for his music. I just mean he doesn't need it for any other games. There's no GPU included in...
Yeh I'm sorted for Windows. I've got a copy. Legitimate of course. Cheers for that build I'll consider it.
I just need the bare minimum graphical ability to run the 3D match engine on max. Apart from that I want speed. Can you recommend a build. And do...
So I'm confused what you're recommending? An Intel CPU and a cheap GPU would be a faster option? I know the graphics are dreadful and would only...
Really? So the AMD APU would be pointless then? Gonna have to have a redesign. Yes he wants to watch the matches in 3D. I was trying to squeeze...
Cool. So what's the difference between socket FM1 and FM2? I'm guessing FM2 is the latest one?
I have a friend who wants me to build him a PC for the new football manager game. He will obviously need it for other browsing and word processing...
Turned it off and on a few times. Restarted a few times. Disabled then re-enabled my ON BOARD sound and restarted, then it started working again....
Well I've not got a restore available unfortunately. Uninstalled and reinstalled the drivers to no avail.
Just transported my PC to a friends house for a lan party. My audio device was working fine an hour ago before I drove up here. I've connected my...
Heya guys. Me and a friend are looking to go to New Zealand for 3 months in July. I want to be able to capture some great photos whilst I'm...
