This reminds me of a review on bt years ago for a shielded power cable that claimed to improve ovrclocking. I can't find it though...
The installer i linked to still requires the original disk in order to play
It is basically a new installer that allows you to play syndicate wars on a modern OS, I was playing it on win 7 64 last night.
On the subject of syndicate wars, I have just found this, installing it now.
Presumably a striped raid array would make the device useless?
10 years and not a single good game yet. Just goes to show that with enough money the advertising view can sell people not only their own feaces...
Sorry to be pedantic but I've just spotted a small error in the graph for peak power consumption, the AMP is labelled as a 280 and not the 285 ;)
I like your thinking ;)
That's going to be irritating. I'll try it out with the GX2 for a while and see if I can get it working. One more question, 2x2Gb or 4x1Gb?
Does SLi automatically enable/disable itself when in games or do you have to go through the driver application to do it?
I know that was the solution when I first built this rig. I assumed it was going to be the same situation. I suppose if the GX2 doesn't work I...
Cooling isn't going to be an issue, I'm running water cooled as will all the gfx cards. As a result I'll also be running aquacomputers 9x120mm...
I'm going to be getting a 26" (1920x1200) with it. The second monitor will be a 20" (1680x1050) I could *just* stretch my budget to a QX9650....
I was looking at getting a Q9450 with 4Gb OCZ PC9200. I know when I built my current computer there was an issue with multiple nvidia cards...
Hi all, It's been a while since posting here but I have a question regarding multi monitors in SLi. I know that I can't run 2 monitors while in...
that explains it, ta
I've OC'd the 4600 to 220Mhz, I've also just tried installing rivatuner, and the clock speeds are definately changing, but they change back to...
Hi, I'm trying to O/C my 7950GX2, I have installed coolbits and have set the clocks to 550/1300 for now, this has been tested and applied....
I currently have it set up outside the case and resting on a cardboard box, I have tried reseating them multiple times and in both slots.
The error code shows up as a graphics error, but I have tried both graphics cards on their own, in both slots and reseating them. Does it sound...
