The NVENC is very efficient, I will try that way
Yep, all Ballistix kits uses Micron Rev E (and with always a great chip quality)
Main question is, do you really need 32GB ? But to answer, yes is possible, I found it almost easy with Samsung b-die and Micron Rev E, your kit...
Keep in mind that the Vega 64 is a very hot GPU, if you have a small case you will end up with a lot of heat to remove
Unfortunately no, but higher models or Alienware usually might have a chance to be replaceable
Avoid corsair kits, take a Ballistix instead, cheaper and far more potential for overclock, every Ballistix kit I've tried was able to be pushed...
You can find it at PcComponentes.com a Spanish shop that ship in all Europe, I use them for a lot of parts, 100% Trustworthy, I bought and...
Only one? I will build everything :D and I'll buy a liquid nitrogen generator all for myself :)
With the right components yes, I have a Seasonic 520W fanless and paired with a low noise GPU like the 5600XT or the 1660s youcan build. a pretty...
That is another issue, but hopefully the protocols will get better, I tried the service and isn't that bad even with a 4G connection or a WiFi...
More competition = less money we have to spend to buy something decent, recently AMD had done a good job in the perf/price segment
With the actual prices for the IPS it doesn't make much sense
They should do a BYOL model, an IaaS for who want to bring all their games and pay only for compute and storage
eBay and DYI replacement :D
Premium quality, I've used them in various builds, totally worth the price.
I would avoid that kit, instead you can look for the HyperX Fury 3200 C18 1.2V, or the Sniper X 3600 C19, or, the best DD4 kit you can buy, Gskill...
The 3600/3600X seems a great chip for a value upgrade, but memories are important, and a good kit should be taken in consideration, if not B-Die...
