Thanks for the recommendations guys. I did just try torchlight but it doesnt have an onscreen co-op LAN play only. :-( Oooh...
Hey all Looking for some recommendations for a good button mashing hack n slash with an easy character progression/upgrade system. That I can...
Got mine enabled and cyberpunk seems to have a few more FPS. Assuming 3DMark is listed as supported will give it a few runs this evening. Msi...
My Aqua-Computer Flow sensor high flow NEXT just arrived (thanks highflow.nl!) Anyone else using one of these and have any tips for pre/post...
Thanks for the tips @Yaka, I've been watching the video series and its really great. Not sure I will be able to grow a moustache like that though!
Hi All, So I'll be starting my venture into using hard lines for my setup and I was hoping to get some recommendations on all in one tool kits...
No, I have an aw3420dw so its just perched on the desk underneath it. Not a massive problem as only use it when I play with my son but a stand...
Picked up a brand new one for £25 inc del on Facebook. Works a charm, thanks for the recommendation.
Thanks, does it do the audio over USB?
Hi All I'm looking for recommendations on a sub £40 pair of USB powered and connected (no 3.5mm jack) desktop speakers. Have been playing No Mans...
oh thats not so bad then still got two years to go :0
Wow it really has been a decade hasn't it. Logging into my account and scrolling through I had totally forgotten about the golden ticket and how...
Nope Windows has gone back to its Evil ways so I am using the GPO to block what ever it is doing!
3.2 of the Samsung NVME driver has come out which seems to solve the problem without requiring any work arounds.
Apologies for the late reply. RL so hectic! Thanks both for the replies.. I used the GPO with the device ID's. Hopefully that will hold firm!
Will keep looking will hopefully dredge something up as it is awfully annoying.
Every now and again I notice a drop in performance of my Samsung NVME. I test this by running ATTO in default mode and everything is capped to...
Happy to loan you the tool to delid it if you want. Or can delid for you and apply liquid metal. My 4790k was ludicrously hot though and was able...
