No cancellation here - still pending on paypal and their site. Each day I get a little less hopeful though!
If it isn't silly expensive then go!
Regarding methodically searching for signal - there must be some sort of hand held device that can scan for mobile signal much more effectively...
Quite remarkable isn't it! Will 120 suffice or will you be hunting for more? Did you use the built in antenna for this test?
It's inside the roof - It was affected by snow a bit but it was still usable. (think 20ish down) I think it would be better outside but our roof...
Just want to drop a thanks Tad - we are now running one of the Poynting XPOL-1 antennae from Amazon and getting some great speeds. Previously we...
I have had one through from the logitech store since new year and it took less than a week; worth placing an order if you need it. If you can wait...
Welcome back Bennie :)
May the relix be with you Alessandro. (cap still on my keyboard to this day!) [IMG]
The logitech webcams are such a clear example of one of the effects of Coronavirus C920 was on amazon for £24.99 at one point, you'll now struggle...
Something to consider with 4K is the lack of content, will you be getting 4k content online? Most 4k content films to make use of the TV are going...
Cheers for the info Mister_Tad. As mentioned by GeorgeStorm above we are getting the occasional websites failing to load until you hit refresh....
did the snow sit on the antenna itself? Ours is going to be inside the loft rather than physically externally as I don't fancy getting a cherry picker
@GeorgeStorm do you have any issues with weather affecting speed? Are you using an antenna? Cheers!
@Mister_Tad revisiting this again too, having placed our 4G router in the loft we are finding speeds of 30 down (a great improvement from the...
Ideally semi or fully modular, I'd hope under £100? There seems to be lots of choice but little to distinguish between
Evening all, I'm considering a fresh build as my sig rig gets a bit long in tooth... Spec I'm considering is as follows: CPU: Ryzen 5 3600 Mobo:...
I am running the stock intel cooler at the mo so not going to fiddle with it just yet. I'll have a look at some coolers, the Hyper 212 is catching...
Hey sandys, I often play the zombies mode with my friends which I recommend! I also played a couple of games yesterday with task manager open on...
Yeah quite right George, thank you. will leave rep for all that have posted.
