I had a load of wonky problems with my E6400's trackpad and keyboard, I just had to disconnect the ribbon cables and clean out the connections....
NTFS, basic, primary partition.
So I got tired of the slowness of my external disk and decided to shove it inside my laptop (which had a spare HDD slot... it's quite a big...
Anyone else, or has my machine gone nuts. Since the recent steam update, TF2 seems to disable 'visual effects' when it loads. Plus, and I can't be...
It's not cheap though! Easy enough to buy a bike for £50 rather than join this for a year. I suppose it's 'easy', could be a pretty good idea for...
This is quite an interesting point, although I'd suspect the dock is just a USB hub and the separate drives dock via USB (and perhaps even usb...
My whole PC, apart from a pair of big HDs, is built from second hand parts. I upgrade it occasionally when I find a bargain [second hand] part on...
I was always most confused that I couldn't buy stuff with my 'gamerpoints' :o I thought that was such an awesome idea, until I realised that MS...
This surely won't last long once they realise how much you're using the mobile internet, which you should be using for a couple of minutes to buy...
Has the power connector somehow come loose from the card?
Have you got one of these you can try with? http://www.evga.com/support/faq/files/pcie%20pwr%20adapter.jpg edit: whoops just read above, clearly...
Did you find it on the UK site? edit: found it http://www1.euro.dell.com/uk/en/business/Laptops/vostro-v13/pd.aspx?refid=vostro-v13
Nah I used a zalman with the 3pin fan header plugged into the mobo... Tried it in the other board yet?
Hm as I recall you checked compatibility for YOUR motherboard with this card, but we didn't check for the ASUS (and I never tried them together)....
Just stick it on the desk, last time I checked wood wasn't very conductive ;) This was my card, which ran perfectly for years in my gigabyte...
It's an odd one to throw into the ring, but try a wetherspoon mince pie (if you dare venture into your local hive of villainy). They are bloody...
You can get the orange box on xbox 360 and thus indeed can play TF2 to your hearts content
wahey!
As NuTech said, if they have really done this it's amazing. Does anyone know of a way to do this type of thing on a relatively high speed LAN - if...
Bioforge. I persuaded my dad to upgrade from an SX to a DX2 just for this, £120 I think. I got to the end and didn't have enough battery power...
