3 of my friends ordered 5900x's on launch day - so far only one of them has actually got their CPU.
Would recommend a silicone grease over a petroleum based grease - they can sometimes cause o-rings to break down (depending on o-ring material,...
Yeah some of it is waaaay over my head. Yeah it's a pretty bright light we generate - but that's what you need for an atomic level microscope (the...
Nope - the area pictured is subject to fairly high levels of Photon Beam Radiation - so it's usually clean and empty (of people and coffee mugs ;)...
I'm not fully up on the peer review setup - but your assumption is generally correct. There is a lot going on and papers do take time to be picked...
This. My life this year has been supporting our scientists working on COVID-19 and how to beat it (I work for a large scientific research...
'Intel Cryo Cooling Technology'.... So will this cooler achieve 123°K? :rollingeyes: (It won't)
No reason you can't re-use your GPU in a new system - obviously you are going to be GPU limited. I know stock isn't that great right now, but if...
Ah, okay, fair doos. If you are only looking to set a speed and forget, why not use the single channel PWM fan controller and then use a fan...
My recommendation to you would be an Aquacomputer OCTO: https://shop.aquacomputer.de/product_info.php?products_id=3832&language=en I have a...
[ATTACH]
So you did :)
Hackaday did a nice writeup on it: https://hackaday.com/2020/11/02/new-raspberry-pi-400-is-a-computer-in-a-keyboard-for-70/ Looks like you get...
Nice little project :thumb: Love the case and all of the oldskool gear - The general build, open relays, VIR, bakelite - my money is on early to...
It took me a minute - cracking idea! I didn't think mounting holes were big enough either (Looks like the LGA2066 socket has some decent size...
:worried: There seems to be a chuck key in a chuck without a person on it
Sweet - looking pretty pro there Nexxo ;) Does this mean there will be an Ada update soon? :P
Benn playing for over 4 years now - I love it. It looked a bit daunting to start off with, but it's so well thought out and rewarding to play....
I have an AC68U running Merlin for the last couple of years - great so far :thumb:
Nice work dude, just read through from the start. Looking really nice - the hex wrap is cool!
