Yeah, that's fair enough really... Not really an AMD guy, but sometimes I wonder if the greens just have a better PR department!
http://www.amd.com/en-us/products/graphics/server/s9170#
Just so I'm clear... There's effectively no current benefit to the user and there will be no change in capacities etc at the moment? If...
When I first saw this I thought "great!". I thought it was a keyboard with a secondary touch monitor, which could be used for anything (or just a...
Yeah, they simply won't put me through to anyone on a higher level... and yep, you can guess why I quickly got bored with the software side of...
No worries on the late reply! I ended up with 12 examples of machines working perfectly before taking it to them in the end. But they said they...
Yeah, they say it's normal, which is why I'm after some screenshots to show them otherwise. The problem is, once they say it's normal, it seems to...
Sitting here just watching iStat at idle with a coffee now... :) CPU: 52c CPU Heatsink: 45c HD: 32c Aiport Card: 35c Enclosure Base: 32c...
Yeah, it does spike to 1.6 for a few seconds from a (literal) cold boot. Then it quickly falls back to 800MHz. You can see on the second screen...
Yep wuyanxu, that's exactly what I think's happening. It slows to a crawl... I just don't think it's normal you see, expecting the processor to...
6 MINUTES? Don't make me cry! Well, that makes it 50/50 - either my machine's broken or yours is :) I tried it with the CPU test from...
Sorry, I don't mean 50% load, it's at 100% load, but the CPU has dropped from 1600MHz to 800MHz to prevent overheating. Which is what I sorta...
Hi Ladies and Gents! I come here again to beg for some help. All I'm hoping is a couple of you might be able to help by posting a screen shot....
I must agree that disabling the pagefile completely is a bit of a dodgy plan. Not just games, but a fair number of programs don't like it when you...
I bet in 5 years we'll all have 6 of these drives (well, 256Gig anyway) rolling around a draw somewhere cos we're too busy using our 1TB ones.
The people who are thinking this up must be rich and making enough money anyway... surely? If they had a normal income like the rest of us...
Do you still require the full version of Visual Studio for mobile apps? As that's a massive cost to enter the game!
How about just including a PATA -> SATA adaptor in the bundle with the motherboard? I'm sure they used to around 2002 or so, there's a box full...
You can only run cards which use the same driver on Vista as standard... So if the onboard graphics and the addon use different drivers from the...
The reason for this is if you look at it from the other side. Netbooks are cheap (well, they're suppost to be anyway), so the OS has to be...
