ok guys testeed the system lastnight and now it just freezes up on me now and does nothing i have to hold the power button to reset it! any...
just worked perfectly! :) thank u dude gonna stress my system now make sure its all good!
police
ok just had a look and the rated voltage is 2.10v but in the bios i could not find the current voltage! so im at a loss?
far to say i perfer the old THQ logo! the new one is not to my taste!
should i try to change the fsb;ram ratio? would that work? but i did notice i would have to bump that up quite a bit to get 1066 out of my ram!!
i went to the bios went to the tweek system and changed the ram from auto to manual then changed the freqency to 1066 i did look at the site too...
like
Hey there guys its been a long time since i have been on here, but i havew a problem which i cant seem to figure out! i will give you my specs...
i love the idea of this! what a machine you could use with this and just think of an entire wall as your screen to use this on. It would be like...
Have to say facebook is S**T i hate the site what a load of rubbish! why would i sit on my computer and talk to people when i can go down the pub...
if your after good music playback then i would advise to get a set with a sub woofer! same for gaming and watching films on your comp with....
It has a 3.5m jack on the back for audio in! So just gonna use a phono to jack cable for audio!
Hi guys I need to know if there is a scart to VGA adapter? I have an lcd but want to plug my DVD player into it but can't cause it only has a VGA...
foobar is what i use! http://www.bit-tech.net/bits/2007/09/12/pc_audio_101/1 check it out!
was just thinking the same thing! then he could sort it out there and then! :idea:
I agree with this but do the simple options first, check connections and turn off the onboard soundcard! if no joy then i would reset the IRQ for...
well peeps NO porn NO go for me! i will stick with tube8.com funny thing is tho i stopped watching porn a few months ago! so what am i...
many thanks dude! will get cracking asap on that!
I allready have server 2003 on cd with key! Just wanted soming new to do!
