Hello I noticed that some of the other threads like this were kind of outdated, so just trying to get some new info. Basically, I dont have...
Also, was just looking at this: DFI Lanparty NF2 B...
Hello First off, I had 2x 120gb SATA Drives running in RAID 0 on my computer. Those work fine. But I also have another 2x 160gb SATA drives...
it would have been cool to leave it wide and mount an lcd in between both comps
that is some of the nicest plumbing ever, considering all of the stuff you are cooling
Hello I am looking for a 5.25" Front panel that has all of those plug ins and options (audo, USB2.0, Firewire, SATA, Memory Card Readers, Fan...
A far more effective approach to cooling a stock Shuttle: 1. First, cut out the honeycomb backing to your case, the entire square. 2. The fan...
[IMG] Wow, that looks awesome. Just wondering how you did that. I saw the tape on the window before and so I am thinking some sort of...
that looks amazing. please more pictures and comments about it.
Also, I put a fanless Zalman heatsink on the northbridge, to help reduce the noise. The temperature inside the case, as reported by MBM5, is...
Hello I just recently purchased a Sk43G for my HTPC. Not the latest and greatest, but with the parts I had it is more than functional for its...
***Sorry, but I do not have the option to create a poll. Please, can a moderator make one for this thread*** I need the following information...
http://www.emachineshop.com/ You can use this companies CADD software. It includes various types of metal, all different thicknesses, and...
Small update, nothing really interesting. But I have a question, possible solution for that power supply question I had earlier. [img] This...
I have a new problem. The power supply had a wire running from the middle prong on the outside connector to the bottom of the power supply case,...
Sorry for the double post, but it said that I had too many images :( Here is the rest: [img] Now for the rest of the motherboard. First,...
Hello First, I would like to thank anybody that answered any questions I have asked. I've been constantly reading logs and vsiting this site as...
Hello I was wondering if the mounting holes on all DVD-CD drives for laptops were standard, and the sizes of the drives as well. I would like...
First, I would like to thank anyone who replies to this post in advance. 1. Where can I get the pins for the ATX / 20 pin connector that...
Thats actually an AIW Radeon 7500, that metal box is a TV Tuner. I use a PCI Riser slot, but the reverse type to lie it flat against the board.
