Hello bit-techers!!! I need your help. I am in need of fitting diameters. I'm talking about the total diameter of the fitting not the diameter of...
Welcome to CASE EVOLUTION. Your probably wondering what Case Evolution is, Well,... just Like Liquid Evolution. Case Evolution is a NEW style,......
Liquid EVOLUTION Beam me up Scotty: xPO352r POD254z sPL932g hAF534T RPL213u xPO352r, sPL932G & rSCB432s - Limited Editions xPRZ5331r &...
BLACKOUT [img] [img] [img] [img] [img] [img] [img] [img] [img] [img] [img] [img] [img] [img] [img] More to come,... soon to be complete.
... dont know if you already seen it but you must see it if you havent. http://www.ebaumsworld.com/flash/rubberjohnny.html
Hey,... I'm new here. I came across this site and saw some people I know along with thier worklogs from another site. So I thought I would post my...
... will it be deleted? I already have a home for it,... I just want to get it out and about so everyone can see it. I copied it over to...
... these fiber looking clumps started to form. By time I was done it looked like someone shook a shag rug right by the wet surface! Why did this...
... to the mobo tray. Now,... is there any particular direction the ports should be facing? I know that most people have the outlet facing up...
... off of the composite. Is there an composite jack on the back of them already or is there soldering required?
Cpemma,... this is really for you but if anyone else knows, please help. I installed a PSONE to the front on my machine. I need to feed this thing...
I have been trying to find this artical or work log where this guy sleeves and modulates his PSU. He uses these round connectors that I want to...
... do they have POS and NEG terminals? If so would I have a problem with shorting out the PSU with them like 3.5mm stereo jacks would?
My 6800GT does not support CSYNC, obviously. I want to make make a CSYNC circuit to get this LCD working. I don't really no anything about...
... and I wanted to know whether or not an EVGA nVidia 6800GT supports CSYNC? I heard most geforces don't but I couldn't find anything that said...
I have to hook up two 120mm 105CFM YS-TECH fans to one set of wires. I believe the wire I have is either 22 or 20 guage. Will this size wire be...
... I dont think it was in the project log forum,... this guy was making a custom pc using autocad and cnc. All I can tell you is that it was VERY...
I need to know whats a good Auto-Cad program? Free or Fee, doesn't matter.
I looked through google and really didnt find anything?!?!? I know that frozencpu sells them but they want $0.50 per pin!!! Thats nuts. I want to...
