looks good mate so far! Always love scratch build HTPC :)
Hey Phinix, when you cut out those "in shapes" out of your 5mm Acrylic with your Dremel, what drill bit do you use ?? I wanna cut something...
Pretty nice and simple design and very effective. I am also building something like that for my 2nd Rig.
Nice!, I will find a 2.5mm anbd 3mm Drywall bit to fit into the Dremel's collet. Thanks again to both posters :)
Yeah, Ive used the plain old wood Drill bit, does the work, but kinda slow and melts the acrylic. Just wanna get some good advice before I get...
Hi guys, I was reading some project logs and found something I needed to read about. It was about using Fine Drill Bits on the Dremel to cut...
