i'm sorry but i just have to laugh at the last 2 post i understand what both of you guys are saying but come on in this case the whole...
techx well just to clear some things up here i was just stating what i did for a router table but anyway
i would look for a 1/8" shank 45 Deg Chamfer with at least a 3/8" cutting length bit but i dought you will find a bit to match in the 1/8" shank...
Techx Ahh ok, But I assume I'd need a table to go with it, i dont see why you would have to buy the table, what i did was, i bought a sheet...
hey thanks for the suggestion spring it was showing up in my computer as drives H: I: J: K: for each type of card what i found out is that...
hey i have a question about win xp sp2, sony ms pro memory stick and kingfox usb to all-in-1 memory reader problem is it will not stay...
i for one would like to applaud you for your achivement on a job well done good job and have fun
great job looks good i'd like to hear more about this htpc when you come up with what your going use for it
that would look cool for the window airbrush the effects around them
great job on the flames man going to have to watch this one blame
hey guys i bought a chaintech CT-7NJL6 mobo off a friend i was planning to use it for my wifes pc i gave $20 bucks for it already had a amd 2200+...
not anymore then anything else we breath LOL
hey this awesome i have an old xbox i might toy around with
check your memory first reseat it in the slots let us know how it turns out
i would just throw the windows disc out and find a linux disto to install linux = good windows = breakage
http://www.tylertool.com/misa.html take alook here
sawsall or jigsaw maybe work better
thank you
talking about Cas Latency which is better 3 4 or 5 thanks
we used a stove set to 200 Deg F and baked it for about 5 to 15 mins then we used a mold made from some scrap wood
