Autocad does 3d too..
http://img62.imageshack.us/img62/2856/taskszl6.jpg screen shot.. as you can see .. as soon as it start to slow all that changes is the "system"...
Well i have formatted both my hard drives, fresh windows install and it is still doing it :( all i can think is maybe something to do with my...
I think im going to just to just reinstall .. pain in the arse but this is annoying me so much now. Ive resorted to uninstalling all of my...
Spec: e6300 ga 965p s3 2gb ocz platinum ram 520w corsair 7950gt 512mb Right the problem im having is every one to two minutes whilst im...
scarey figures.. 4.2ghz
What cpu is it?
2.8ghz is very realistic and its what i am currently running mine at. Temps arent an issue with an aftermarket cooler. Well worth doing in my opinion.
lapping dropped my temps by 6 degrees and i wouldnt say it was at all a hard thing to do. The chances of reselling a e6300 are a bit slim dont you...
Probably was looking at intels figures highland3r, thermal capacity or whatever it is on their site. I would lap the processor if i was you,...
Thats a really good project and a very well thought out idea for what it is. Definitely would come in handy i know that for sure. Top stuff :)
Right a while ago i set up utorrent to use port 72 (long story why i chose that) and since then i have uninstalled it and all that jizz. However...
Yea i have one of those .. really small but relatively long in comparison to their width. Its stuck dead in the top right of my laptop screen i...
Yea definitely do it, the passive cooler really isnt that great. Mine at around 2.8ghz was too hot to touch so i have superglued a fan to it and...
If you go for the ds3 buy a small fan to sit on top of the northbridge. It tends to get very hot ;) also on that note. Trig are you actively...
http://xtreview.com/review161.htm
i want 500 :-p
yea 470 posts fine
After reading this: http://www.xbitlabs.com/articles/mainboards/display/ga-965p-s3_6.html maybe worth going back to a previous bios?
just dropped the multi to 6x and tried fsb 480 and it wouldnt post. I have loosened mem timings to 5 5 5 15 and 1:1 with fsb
