I Love Aquatuning and Bit-tech so much It makes me turn red
Brillant, I hope the new serise will be better than serise 8 which was quite poor to be honest. Cant wait for the new serise. !!!
that is one sweet custom build. Really like how you fitted the watercooling kit in the case :)
It good idea that they gonna strip out picture viewer and windows live mail etc but what about those that do generally use them, Are they make you...
If you get a amber flashing light on the power button of a dell, It does indicate that there is a problem with the Power supply unit
I'm sure you could do this with group policy's (gpedit.msc), and lock things down on user configuration. This is what we do at work to lock down...
Looks good Goo, I can't wait for another update. It sure will be a good kit car :)
Been following this project for a while now, it just keeps getting better. Keep up the good work
thanks for the sugesstions. I have got a watercooling kit that I had on my old pentium 4 rig still laying around in my room. Wondering if I was...
thanks for the suggestions, dont think size will be a issue got a thermaltake armor case. I really do like the thermaltake big typhoon.
thanks for the replys, not looked at the artic cooling 7 heatsink, will see if i can find any reveiws on it.
Hi I'm looking for a new heatsink for my rig as my old one is currently noisey. I looked at the asus silent sqaure pro and the zalman 9700...
I would'nt put the heatspreader back as they say you will get a nice drop in temps. If the cpu is workable why dont you have a aftermarket cpu...
Been following this post but felt i had to say this is a really good ! Keep up the good work. Looking forward for more of your excellent work.
I would have the quad core anyday ! With the intel price cuts coming I would really give it a good think :)
The new setup you got there will be good you wont be dissapointed.
I do believe you can use the recovery console on the xp cd and perform a chkdsk /r /p this should solve the problem for you.. If not a full clean...
wow great project keep up the good work
I really like this, I want one.. Have we got a rough guide on how much this beauty will cost ? :) I really like the touch sensitive idea but you...
Funny you say that Bindibadgi, I have a segate hard disc and this does the same gives loads of lag.
