The empty drive bays hide all the wires, although I could make room for another drive if necessary. The fans pull air through the radiator into...
Water cooled Lian Li PC-V351B [IMG] More pictures
I wanted to show some pictures of a case I've been working on for a while. Motherboard: Asus P5Q-EM Processor: Core 2 Duo E6600 -Water...
Thanks for the awesome comments guys! The drain ports are almost finished. I'm deciding whether to paint it black or light it with an led....
Small update. The bottom of the Mini-ITX side of the case has this hole for mouse/keyboard cables to exit. This is where the drainports for both...
Today I tested the res for leaks. Of course a tiny spot leaked so I applied more of the acrylic cement in that area. I'll test again once it sets...
Hey. My case is a Thermaltake Mozart Tx. Some of my goals: - the chassis will be painted matte black or powdercoated - the cpu and...
Update! I've made some progress and finally got around to making an update. Now that summer is around the corner expect faster updates. Water...
I wonder if I can put the inlet at the top and only half fill the res so the water/coolant runs down the acrylic.
The mini-ITX board goes goes under the power supply as shown here. An ITX board is a low power motherboard that is small in comparison to the more...
I find the sound made by twelve of these is rather relaxing. Here. This is the exact one i bought. It doesn't show any pictures of the case...
I'll definitely make use of all this space soon. I'm thinking of using two seperate 120.2 radiators, one for each loop and definitely more hard...
Hey guys. I don't think this counts as a project log, so hopefully it's in the right section. I want to show everyone my case, what I've done with...
Thanks for the advice. I practiced removing a few rivets on an old case with a 1/8" drill bit and it works great. I will need to buy a countersink...
Hey, im new to bit-tech and im very new to modding so I'm hoping someone will be able to give me some advice. I've been using the Thermaltake...
