For the 30" monitors my budget will not go that far means more waiting and i can not justify spending so much on a monitor.
I would first like to say thanks for all your help on my Rig. It runs Great and is still performing like it should. When i got my PC i already...
Well i will change some bit and i will change the 140mm fans later maby as for the drives I changed them just after i made the post order made. I...
When spending a lot of money i want to get the best. here is it the last build i hope going to put my order in to scan when i get home. will post...
Thanku for that taking a look now nice one
This is the Rig i am planning and as a sugestion in my othere post I think it will be good to get some water cooling in the system big enugh case...
Processor got me thinking built my first pc back in 2000 and it got me thinking started work in 2008 and in all my time i have not seen one go is...
Not done a water cooled rig befoure and tbh i dont know what products are good how long a pump lasts what coolent to get. what pipes to get nothing
Ok guys i have Cut down the cost 6gb 1600Mhz 9-9-9-24 ram 750w corsair Nice power suplies all i read about them is BUY BUY Corsair 800D PSU...
Water cooling have looked in to it and tbh it just makes me think ARRR WATER IN MY RIG LEAKING i would really like to get a nice water cooled rig...
Right ok will post new items in 30 mins or so 800D is the corsair Obsidian 800 wanting to upgrade the fans and get more cooling power I do have...
I had 2 1tb drives both went within 1 day of each other. work with a lot of computers and we find one of the main problems is replacing drives...
Update had some car problems and now i am back on track will be getting new pc asap. here is a updated list of what i plan. i have put up my...
Going for the h50 i think it looks nice its minimal on the board i cba with a custom water loop and would have to drain it when i go to the...
the Corsair H50-1 has the better cooling tho i understand
There is a couple of coolers i have been looking at for my cpu. Corsair H50-1 Titan Fenrir V2 Xigmatek Thor's Hammer with fans all...
Overclocking will aswell so no loss want the best temps i can get
I am buying a 920 cpu and am going to overclock it ofc. i have been reading in to lapping and sanding the cpu to make it flat. and been reading...
I usually play games and watch tv or browse forums and watch tv.
i want to know if it is possible for ATI 5970 to run one monitor and for my gtx 8800 to run my secound
