I resorted to reinstalling Windows, thinking that would surely fix it... nope. (I needed to anyway due to finding a damaged sector on the hard...
Hi, I have a rig that was running Folding@home OK on a GTX 260, just a bit warm and noisy so I decided to replace that with a GTX 460, but it...
In my defense, my build was only at the testing stage and I was only using this PSU for testing - it provides enough power... I just think there...
Ok, so I bought an ASRock P67 EXTREME4 motherboard from ebuyer a month ago, did a bit of overclocking of a 2600K and got it stable and folding...
Oh yes, my mistake, for my GTX 460/560s I'm using the GPU3 client v6.41 and I specify -forcegpu nvidia_fermi
Yeah, run the GPU2 client along with the CPU client on a single CPU core so a core is free to feed the GPU with data. I use GPU-Z to check the...
With such a low budget why not look at it from another angle? Look at what you will use the computer for, and make folding the secondary priority....
Thanks Christopher, you got me on the right track and I've sorted it now. I just had to add -forcegpu nvidia_fermi to the shortut target for the...
Hi all. I previously had two GTX 260s in my machine, 'happily' folding away. One had been running too hot for a while so I've just replaced it...
I never knew this either. I have two (non-identical) graphics cards and three displays. One card (the one with two displays) does run a little on...
I think I came across some problems myself with trying something similar. It was an XP setup but I think the problem was because installing...
You might still have a 'leak'? I had this problem with my watercooled system, one of the fittings wasn't brilliant, it didn't actually leak but...
At work work I listen to the quiet hum of computers... when working at home I listen to the louder hum of computers being drowned out by Kerrang...
That almost reads "EPSON-USB3" :D
If you have two spare molex connectors just just a molex(x2) to 6-pin adapter. I do with my 400W Corsair :D
Unless you're a folder :D But yeah, the temps are fine.
Ideal for those risky overclocks!!
Ask for the removal request in writing.
I've recently had to ditch a Gigabyte AM2+ motherboard that was causing my CPU to overheat and the system to shutdown. I was using it in a...
You shouldn't use a spare internal hard drive to backup your data, mainly because if you lost your main hard drive due to a power surge, the surge...
