I'm hyped after seeing the gameplay trailers. Doesn't look dumbed down much at all. Separate exp and aug trees, a good number of augmentations, a...
Given that in all of the reviews you posted the 560 outpaced a 6970 in numerous games, it is quite disingenuous to post that as saying a 560 will...
I've got a frio and am very happy with it, apart from the whole I never really needed it for sandy bridge thing.
I could go in to the long list of mods I use, but really it can be summed up as CCMAT II by by Sneaks and Jooyo found here. The balance for tile...
I love Civ5, and think it is the best one yet, but only after my set of mods are applied. There are some massive balance flaws otherwise.
The speed of SSDs is mostly in the seek times. While RAID arrays increase write and read speeds, they can't improve seek times. This matters...
As some one who just built the same build recently, the only change I might suggest is swapping the MSi for this...
Hmm, unless you find a review or bench mark comparing the two it is hard to say for certain. I've got the MSI, and I've got to say I'm very happy...
Am I the only one who is starting to get slightly annoyed at the whole "mil-spec" meaningless term that seems to be used more and more?
The only convincing reason I've seen for going for a more expensive board would be to SLI/Xfire it, it doesn't sound like that really is needed...
I'm in the field I guess but that isn't really how I see it working. The help knowing interaction and structures of proteins provides is...
Off topic but okenobi, you are second person I've seen using fill your boots and where does that come from? I think I get what it means.
The OEM 2500K version saves you 10+ quid, and after you factor that in you are not even paying 5 pounds to put on a hyper 212 or Freezer 7 Pro...
The question hovering over the 1Gb 6950 is will you be able to mod it to a 6970 still. Without that the overclocking power of the 560 will still...
I'm broadly with wuyanxu, but if you are new to all of this and don't really think you will ever get round to overclocking, just get whatever...
The 560 is a lot more powerful, but really it depends on the rest of your system. It isn't worth blowing all your money on one part and not having...
I was looking at the 6950 -> 6970 trick too, but the 560 seems to match the 6950 before overclocking, and beat the 6970 after overclocking (unless...
So that man just has ridiculously small hands then? Anyword on what it is going to cost?
I haven't had any problems yet with my P8P67 Pro, beyond a faulty Chassis fan 1 plug, but then again I've only been using it for 4 days now and I...
I'm afraid the Geforce 560 on its way begs to differ.... Pity I have only til I starve to death to use it.
