Check your mobo manual's "beep codes". Temps are fine. You should check the memory (DRAM) voltage to be sure you're using the correct voltage.
Better yet, the Vertex Turbo -- comes with 1.5 firmware that has TRIM and Garbage Collection (GC) built in. About 150USD.
One could certainly say, sooo ... AMD needs to come up the another Athlon 64 Intel killer or, sad to say, don't see them in the high-end market...
make sure the Intel X25-M is the G2 version
COOLER MASTER Hyper 212 Plus http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065 Hyper 212 Plus wins a 10/10 review from Maximum...
Perhaps we'll soon see a new World Record 3DMark Vanatge score from Shamino soon ...
i was also just wondering would i see a big fps gain going from an amd fx57 > i7 while using the same graphics card? The i7 is a much more...
Get: ASUS x58 mobo Corsair DDR3 1600 ram (3x2GB) Intel i7 920 ThermalRight Ultra-120 Extreme (TRUE) OCZ Feeze thermal compound dual 120mm...
+1, and Antec Signature Series (made by Delta) is next best. Given you aren't going SLI at some later date, a 650w PSU would be just fine.
All volts/temps look OK. Time for serious measures. W A R N I N G Prime95 is tough on CPUs so watch cpu temps carefully. Download Prime95 and...
And we're back to this: Download SpeedFan and monitor voltages and temps. Put system in moderate stress and tell us the +12, 5, and 3v readings
coolmaster 335 = good choice! Don't sacrifice burnt up components to the Gods of Quiet or Silent systems :wallbash: That's why I recommended...
ASUS has come a long way since the A8N32-SLI days (I had one myself, but it worked out great for me). ASUS is probably the number one or two...
Toss both overboard and install Microsoft Security Essentials.
Basic mobo but good forgiving OCer: ASUS P6TD Deluxe Mobo with new USB 3 and SATA III: ASUS P6X58D Premium World Record holder: ASUS...
Fans look OK. But until you know your new component power requirements I'd pick a case with good airflow and without a PSU. Here's a mid-tower...
The usual suspects are PSU and heat. As I said in a previous post: Download SpeedFan and monitor voltages and temps. Put system in moderate...
Pretty cases remind me of a gal I was knew, all show, NO GO!
Excellent choice on cooler, it lives up to its rep! I idle 1c over ambient, 68c @ 4.0 Prime95 stable! Dual fans, OCZ Freeze. LIAN LI PC-E8L...
Download and run Memtest86+ on each stick of memory individually. I'm thinking you've a bad stick.
