Hi guys Time for another wooden build of mine. The build is titled AMPC, as in amp+pc. AMPC is a smaller gaming rig hiding inside a case...
Hi guys Im going to start my new build soon and Im looking for help reg a custom alu cutting job. If someone here with access to...
Im curious, instead of a cutting paste, could you use regular heatsink thermal compound for drilling in say, stainless? //Quizz
Hi guys Im back on BT with a new project, titled KOSMOS. I will try to make it a quick one :dremel: KOSMOS is a smaller HTPC/MAME rig for...
Im curious if it be possible to run an Intel NUC i5(4250U) from say a big li-ion battery pack? Not ideal I guess, but possible? Power...
Hi guys I going to make a portable Raspberry Pi device, and Im going to use 4 x 18650 li-ion cells. Now, I know there are Power Banks out...
Hi guys. I'm trying to locate a 7-10" LCD that runs on a 5V line. Found this one, but reading the specs I'm not sure if a 12V line is...
Hi guys, I'm back with a big project. THE TEMPEL I'm in need of a workbench, a place where I can focus dealing with electronics and modding....
Hi guys. I've got a very strange startup pattern. During boot, it freezes at the black "Starting Windows" screen. I then have to hard-reboot,...
Hi guys. I registred for the forum two days ago, so that I could enter a mod in the Cooler Master casemod competition before the deadline 31th...
Hi Guys. I bought myself a low profile board from GIGABYTE, the GA-B75TN. First of all, I can't use my i5 Ivy 3550k(which IS listed in the comp...
Hi guys. Let's say I have 3000 .png files in folder1, and 1000 .txt files in folder2. Some of the files in folder1 are "clones" of files in...
Hi guys. I would like to give Aurora a try, but first some questions: * This is my setup: CPU: Alphacool NexXxoS XP³ Light - Acetal...
Hi guys. I'm planning to build a desk with a built in stealth monitor lift, James Bond style. The basic idea is to keep the monitor hidden...
Hi. I going to have 4x3.7V(=14.8V) li-ion batteries connected in serial and built inside a box, and I want to be able to recharge these. Would...
Hi. I have an Ivy i5 and would like to use it in a very slim SFF build. Seems like most slim mSATA boards with external power supply can...
Hi guys. I have an optical drive that I'd like running without the use of a PSU. Does it really need both 12v and 5v? Would it be possible to...
Revelation While the R-Kaid-R project is on hold, I must have something to do. Sooooo I decided to start my biggest project ever. The concept...
Hi guys. I going to have two battery driven devices rechargable through USB, and could use some help. I guess I'll need a resistor between battery...
Hi guys. I have a device driven by 3xAAA batteries but would like to use a rechargable lithium battery instead. I really don´t want to open up...
