Best I can find is at dell for around £700. Res is my main priority, I don't need too much power, as mainly doing software development, photo...
Hey all, first off just to let everyone know this is not some lame attempt to get people to sponsor me, it's more I just want to raise some...
I have just bought a Netgear WGU624, however for some unknown reason after a few hours all the connect pc's get "limited or no connectivity" and...
Well after Hostgator basically admitted defeat with regards to jsp support. They've stopped providing new accounts with jsp support due to the...
I know the 6800LE can be unlocked (well some can be) however I'm after which is best from stock. If i get a 6800LE and it does not unlock I'm...
Hello there I'm trying to get in touch with rikbikboo. Has anyone had any past trading or contact with him, or even know him personally. ?...
Right i had the logitech RF keyboard and mouse set a while back cost about £100 in its day,but the delay was terrible. I really felt like i had no...
Right well im not amazingly accurate with my demel so what i do is cut out the basic shape and then file down to the lines, this gives me a...
<--Woops wrong forum plz delete one in networking lol --> Ok, i have a page with 4 file fields, and currently each one calls a javascript...
I'm currently making a custom case, as wondering is there a place i can download a standard atx motherboard mount template ? So i can make my...
Help......... I've been trying to work out how to extract information from a string which lies inbetween two tags. I have used perl for pattern...
Hello there, been searching for a while now... Is there a way i can read in a url within a webpage and store it as a string variable ? ie...
I am confused which is best to start with ? Dont really know what i want to do yet, but figgure they all do kinda the same thing ?? Which easiest ?
Ok im reading a file and want to search for every occurance of the word "TRACKING:" it reads the first one and registers it but the ones after it...
i was only asking where they went ? and since you did have close ties i thought there would be no problem in mentioning it. yes bit forums are...
Ok i knew ocs died as a store, and their forums moved to www.ocsforums.co.uk but they gone again somewhere ? anyone know where they gone ?...
Ok me and my mate are unsure which design looks better (and by design i mean colour and layout) FIRSTLY (I AM WELL AWARE ITS A NUKE SITE, SO NO...
How can i plot using decimal locations (doubles, long etc) I want to plus some equations on the screen, for eg.. start X = 1.2 start Y =...
Ok i have found some corrupt jpg files on my flash card using a program called "File Recovery" however they do not load in PSP or PS, as it says...
Having just read here i am unsure http://www.7volts.com/quiet.htm I was planning on 7volting my two 80mm enmerex psu fans and my 80mm rear...
