I think they have some procedure for this although I can't remember where I read/heard it. Probably worth getting up there asap and explaining the...
I've just been having a look around to see what speed I should get (other than relying on the 5.5Mbps my ISP says) and found this site Does...
My ISP (Nildram) says I can now upgrade to 5.5Mbps :D Just checked on that samknows thing and it says my line should "support a 5.5Mbps or greater...
lol. You aught to have waited till Saturday (April 1st) morning after qualifying for an evil aprils fool.
http://forums.bit-tech.net/showthread.php?t=109883
Not just lubing them with WD40.... just used that to displace the water afterwards so it didn't all rust again. The original grease is still...
Is much of the stuff that needs cleaning/derusting steel? Have you tried using electrolysis to get the rust off? Do a google for electrolysis rust...
I always drive into the house/fence or whatever when I'm parking at home. Best way to get as close as possible is to touch. Wouldn't do if my car...
I had one like this. Going onto a roundabout that was completely empty and he stopped while I was looking to my right. Can't complain as it's my...
Google says http://www.gloucestershireairport.co.uk/ Not a big passenger type of airport though by the looks.
The degrees per second value refers to the maximum measured "rate of turning" not how often it is updated I think. For example the CG-16D would...
Mmmmmm. What happened after she put the litter back in his car? He threw coffee on her and then jumped out and attacked her? Or did she retaliate...
Don't know if you read it wrong or I wrote it wrong but I haven't had any reply from Bath yet (just had a reply from Leeds so far). So there's a...
I've only heard back from Leeds Uni so far out of the 6 courses I applied for. Others are 2 at Sheffield, 1 at Loughborough, 1 at Nottingham and 1...
80 in mine 40 in ps2 40 in sisters laptop 80 in dads laptop 20 in sisters PC 2x20 in old computers in loft 2 in old laptop used for print...
Aaah, got a couple of ones like that... In junior school we were doing about germany and the teacher brought in some frankfurter sausages. I...
And bonus points if she's wearing a short skirt :worried: Or you might just get a slap :D
Indeed. Unless they thought that the suicide bomber had come up with an elaborate double bluff.
http://www.dvla.gov.uk/drivers/vehicle_cat_desc.htm#Cars If you passed since 1/1/1997 then you should only have B, B1 and some other small...
I don't think aiming for power lines is worth the risk. Imagine landing one leg either side :waah:
