If you look at your rail link to spawn, you'll find a new tunnel all to yourself currently under construction :p Your more than welcome to the...
What you are in fact looking for is a NOR gate - An OR gate with a built in inverter! A 4001 is a CMOS quad dual-input NOR, so should meet your...
erm, notch has mucked something up mojang end - he says he's 'looking into it'...
Multiverse would get my vote - easy to set up and can be used with portals :) EDIT: Oh and it looks like 1.8 is set for release next Thursday
Server ports would be my vote, preferably with the 2 maps loaded with the bukkit multi-world feature rather than 2 separate server instances (and...
yes, it is much more convenient than the unruly leviathan that was the real world mine-cart track!
I'm afraid Aforess (the MM writer) now purely works on bukkit, and no-one else has took up the ropes =/ Rule number one when digging through...
We have a griefer and theres no-one one to stop him D= EDIT: alexjj and machonacos EDIT II: J's here and they've been banned =) EDIT III: J's...
I discussed this with a couple of the players on at the time who seemed agreeable, however, as you think otherwise, I shall re-implement the above...
*ahem* the behind cooling towers fire was me, was trying to clear the trees from my build site and it managed to jump over the firebreak -got it...
Right, I'll probably have finished all the stone/iron and iron pillars when I log off, any chance of a chest with glass and ice being left in the...
I'm fine with it, but I haven't really built anything major on the new server...
You might be interested in the reply to this post then
Modding the drivers from a scanner is unlikely to work if you plan on driving any larger steppers - the steppers the drivers are designed to work...
I can't imagine the stick could have cause it, USB specs have required over-current protection to be included from the start, so the worst case...
However it's normally just the area around cpu socket which gets exposed to condensation when overclocking with ln2 - in this the...
The way ln2 makes fog is by condensing water vapour out of the air - still bad for components =/
Most fog machines I've seen use either pure water or a water / glycol mixture - ie not that healthy for components =/ As for DIY they're...
Nope, both sides are momentary
They (should) tell you and send you off to the nearest powdercoaters (or do it if they can), as it damages their equipment as well.
