if i'm not mistaken, its possible to create an on/off circuit using momentary switches involving relays and transistors.. anyone know where i can...
after my public exams thru the whole month of november.. i'm looking in getting a whole new system... what should i be looking at Intel...
g'day this Q is meant for macroman.. i guess that you are using eagle to draw your schematics (cathode throbber).. and your prolly using eagle...
hey guys.. just out of curiousity... can someone explain to me how i can convert DC to AC... pls list the components involved and give some...
hey guys.. i just finished assembling an AC 12V amplifier kit.. and got the transformer to power it.. it works mighty fine and now its pumping...
reguarding to this article found over HERE how many LEDs can i hook up to this circuit... and if it cant handle much.. how to i increase the...
what kind of adhesive i can use that wont eat into paint? Uhu wont work.. superglue wont work.. polyurethane wone work what can work?!
i recently bought this DIY amplifier electronic kits and assembled it.. for speaker out and ground its ok.. because it makes a thump sound when i...
ok.. updated it a lil bit now i have blue ones for activity and green for idle.. everything is in place.. and the green lights up when its idle.....
ok..i bought this 9v touch switch kit just today.. assembled it and saw how it worked... pretty fine.. i might just wanna connect it to my pc and...
reguarding to this article over here brought specially to us by bit-tech i would like to know if the 4n25 opto-isolater can be replaced by a...
how do you cut a 60 mm blow on a 2.5 mm thick acrylic sheet? here are couple of options i have thought about 1) use a soldering iron and burn -...
i have these knobs which is just a piece of metal surrounding some black round plastic... i have drilled the indicators out on the knobs and now...
anyone know what are the voltage and ampere ratings for BLUE and WHITE SMD LEDs like those in your mobiles? they are 0603 types? please help!...
Which is the best affordable mobile rack i can get? and what do you think can beat the lian li mobile rack in terms of price and performance?
couldn't p.m you .. couldn't email you so here it is.. i've read a lot about your mods and been trying to apply some techniques that you have...
hello.. ok ok.. capacitors store charges of electricity and all that but can anyone an in-depth explaination on how they work.... how i can use...
hello guys.. read the article about the rheobus you cant overload stuff... and i would like incoperate some SPST switches for each individual...
hey! i'm fully aware of this 7 volt trick and i've made a baybus etc etc which uses this principle.. however, i recently heard of a 17V trick... i...
i recently bought this set of chrismas tree lights which were blue in colour.. the only thing was that it was always on... how do i make a...
