Hi Ive got a laptop with broken LCD, and i was wondering if it was possibly to change it to a smaller one, like 5" or something so i can fit it...
hehe...yes it was a interesting page there :) though i was thinking radio freq. transmission... ill have a look at these Holtek IC, thanks!...
Hi Ok, i know this is OT, but since you gurus are the best i figured id give it a shot. Just wondered how a normal car-alarm worked,...
this is what you are looking for; pased from Linears IC-workshop thread (a thread you all should have read :) )...
hum...im not sure what you mean. what i want is that when i make one of the four outputs on Control port 'high', i enable another 8 outputs...
id like a copy too :rolleyes: thanks :) hylander@home.se /Hylsan
since i havnt got any replies, i take it as i am right about the wiring. hum...if they are almost the same can i hook it up just like they do...
it might work :) you like your serial plug, dont you :) /Hylsan
its a nice little gadget youve made :) a thought arose tho, why limit yourself to just one LED? ive just finnished a "LED-array" of 8 using...
little brainstorming; since you can figure out how many seconds it will take for the servos to slide down/up, you should be able to use a Timer...
ah...ok :D /Hylsan
hum...looks that i was right...it was my soldering skills that was spooking around...i think...after de-soldering all connections i noticed that...
hum...ive connected 8 Leds with the parallelport and a resistor before it @ 500 ohm. fault 1: when sending 255 to them all are lit as supposed...
just come up with a VERY crazy idea...i wont even tell you it right now :p how does glowires light up? ...do they light up like a ordinary...
humm...ok im not so good on IC-circuits yet... but a quick glance at what you want, isnt this what you want?...
exactly...they sounds like perfect for my console panel :D now i only need a interfacecard aswell they i finnaly can start on it :) /Hylsan
ok i know you want the "door" to slide up down but... if you would want it to go 90 degrees and then slide in it wouldnt be that much trouble...
so...if i use the 573 as input i should make LE high (+5v?) and connect the OE as a clock? (pin 14,16,17 on pport) is it ok to combine these...
dont they use 74374 as outputs? or are they the same? /Hylsan
hum...you dont happen to have time to show me how i connect it to a parallelport? just a simple paint-diagram that shows how i connect 2 of em...
