Hi all, Im pretty new to access and VB programming and am having a few difficulties. First, I have wrote a VB for my access page that will...
that is pukka, thanks mate, i appriciate it. From a operators point of view i feel it will be easier making a database in access, can all this...
yes, but Pencom Design example shows that you locate Microsoft Communications Control in the additional controls menu, but I dont seem to have the...
Hey nick, Where did you put the API files you downloaded, i put them in windows - system, but nothing showd up in the additional controls of...
Yes, thought that might be the overall comment. the pricing structure is something I dont have the power to change unfortunately. But if you ever...
cheers nick, The pin outs in the clare tester are (9 pin) 2 = Rx, 3 = Tx, 5 = Digital Ground, all other pins are not connected, sound right??...
so the data link wont produce a seperate file for each test, it will only produce one file in the lines will be added to that file for each test....
The fans are availiable from RS Components, and are some of the advanced fans currently on the market Anyone currently using them
Hello all, I am writing this thread to enquire whether anyone uses cooling fans made by Comair Rotron. If so, I would appreciate any comment...
thanks one-zero, so is it possible to import the data straight in to excel in real time, I.e, when the test is complete, the data comes up in...
Nick, you are a gem, thanks mate. Can you further explain what you have put, Im a bit of a noob So the 19200/no parity/1 stop bit is what i...
Its basically a Clare G102 Genius lite Advanced comprehanive test station. It incorporates 4 interfacing ports, 3 RS232 ports used to provide...
anyone help
Not sure if this is the right section, but does any one know of any free/cheap software that a data log information sent via a serial link (RS232...
ok, i am trying to heat the thermistor up too, but will it only draw what current it needs?? How is the best way to heat it up to a know...
I.E, Do I subtract (if I use a 100R) 100 to the resistence values of the thermistor
I got you. so if i measure the current across a resister, how do i take in to account that resistor in the calculations???
hi cpemma, Sorry to be so dumb, but can you explain that more, dont quite grasp the reasons. Also, how do you calculate it (what...
well, the resistence I read was 5240 ohms, so from ohms law @20v it should read 3.3 mA, but Im not picking up anything
Can some one help me, im running some tests on a thermistor, to basically see if I can heat one up to a required (internally heat it by putting...
