what do you think about the lcd and pic cotroled fans? Could you draw some schemes? And i'm waiting for the the files. When will you post them?
I will give the pcb to a company specializing in making pcbs. I am making the (auto/manual/off) with a shutdown delay. I can't find the correct...
Gladly, but there is a tiny little problem - I only have a demo version of livewire, so I cant even open your circuits :((((. Guess I should go...
Ok im waiting thx. That the site... next article soon http://moded-kompz.net/?name=Mods&id=33
Acrim i have used yours shemes for my article. You can see it at www.moded-kompz.net. (Its Polish site). I would like to ask you if you could send...
heh i am building my megabus... I have allmoust all needed parts (Poland) its hard to find all needed ones...
acrimonious could You plz send me the files in livewire...plz carnage@tenbit.pl
WOW thats a great scheme. Maybe i will add this to my project... Great work...
When?
acrimonious could you send me files in livewire of the schemes. I would be greatfull.THX carnage@tenbit.pl
I have wrote an article about building fan cotrolers, i have used all your schematics. It's on moded-kompz.net (Polish site). Keep up the good...
I made a parts list R1-3 500 ohm R4 100 ohm R5 100kohm R6 Thermistor 100kohm 30'C R7 50ohm VR1 100KPCB VR2 50ohm manual VR3 20ohm PCB...
I am using Proteus 6. http://www.labcenter.co.uk THX for the PCB...
Yeah, why not... What program do you use to draw those schematics?
I will wait... I just bought a few parts. I have to design the PCB first. You are making a great job acrimonious. THX I hope it works? :)
Thank you very much for the scheme. It's perfect, tomorow I will go and buy all the necessary parts and I will make the prototype. Great work. I...
If that's the best way, then let it be so...I look forward to see the schematic.
Yes i know that. I can supply 5v from the rs232 port if i want to... But i want the whole device to be easily plugged and unplugged. Thats why...
OK that's to much for me.. :P Now I can only wait... :) iit's all up to you acrimonious
