The pins that held my Northbridge fan were barbed, so I just used needle nosed pliers to close the barb and they came out easy. When I got done...
Some progress. I have installed my water block on my new KD-7 mobo and Athlon 2400+ cpu (xmas gifts). Details of the install may be found here,...
Depends what you want. The Abit KD-7 totally owns if you want max overclock. It isn't really even close. The Abit NF-7 is so far not...
Yes folks, it's true, the plexi is a radiator shroud. I frosted it with 220 grit sandpaper and will be lighting it with a 4" CCFL in green to...
I appreciate you wanting the great cosmetics. As a guy who has wasted entirely too much time buildling everything from scratch, I can tell you...
I got a K7S5A, and I'm giving up. It's just easier to get an Abit KX-7--they've gotten pretty cheap. Newegg is selling some refurbished ones...
I got curious how much diff air vs water vs pelt vs phase change makes versus various AMD chips and voltages, so I decided to research it. The...
I wouldn't say there's no point to cooling the RAM, a fair number of OC'ers are saying that gets them better performance gains than upping the...
Purple: Glue = Toluene solvent. It's as thin as rubbing alcohol and works by capillary action. Is really the best bet, although it enforces...
Thanks for the kudos! While it has been a lot of work, its also been a lot of fun. Yes, the "trap" (e.g. reservoir) sits above the pump. I'll...
Gettin' a little closer on this crazy water cooling project. I think I have all the plexi fabrication done, FINALLY: [img] Geez that was a...
DIN rails are, as mentioned, used to mount car stereo head units. I have no idea if they are the right size, but they're going to involve screws...
I know a YY Cube when I see one, heh. I just picked up 3 of these bad boys from eBay for $7.50 each: [img] They're going into BorgCube...
I presume you mean LED mod? Still researching that one. I tend to do the research well in advance of the work. Eventually, I want to build a...
So I'm reading about a guy who modded a LAN hub into his system and I think--cool, I like it. Then I started thinking about some stuff and got to...
I just need to fabricate a new radiator shroud and I'm ready to install. It's been leak tested for a week and found to be sealed: [img] I...
Now I know I have been milking my water cooling project for too long. No sooner have I concluded that the block is done, and that with just a bit...
There's two things I'd like to do to improve it. First, I would like to use a cathode throbber to get some interesting action. I am not in favor...
Yeah, I guess that would work. Heh: [img] http://forums.bit-tech.net/showthread.php?s=&threadid=17843
Thanks guys! The green is yet to come as Phire mentions. This UFO mod was a brief sojourn from my water cooling project, which I've been...
