I'm trying to get a load of code working on a PIC18F2550 but I can't even get the simplest thing in the world to work! Here's my source:...
Has anyone had any luck getting a PCI ADSL (Bewan chipset) modem to work under OpenBSD? I'm fed up of having to turn apache off when I'm mid-way...
Does anyone know how to tell the Eagle PCB layout to put some components on the back of a board? I want to produce a two-sided prototype but after...
Hi all - long time no post! I've been looking into building some more elctronics goodies and have been thinking about getting some decent boards...
Simply put, I'm trying to implement two tables to hold the high and low bytes of the PWM register so that I can use all 10 bits, from a 256byte...
For those of you who've not seen my luxeon LED poi, check this out. I've been toying with power sources recently, and have (almost) settled on...
I've been making some progress on the LED Poi I was building a while back (cheers for all the help guys!) and have been investigating ways to make...
I've finally managed to get hardware PWM from a PIC, and I thought now might be a nice time to try altering the duty cycle. Lets do it with a...
Does anyone have a guide to getting hardware PWM working on an 18F1320 series PIC? I've tried using hazers tutorial, the 18F1320 manual and the...
I've been trying to get mod_deflate to work on my website. It's running Apache2 on Windows 2000. I've set it up, and the module appears to load,...
These PICs are ideal for my current project, but ICProg doesn't (yet) support them. Any idea how I can program them? Are there any other free PIC...
I've been considering re-building my linux router using a mini-itx board, but after looking on the web, I can't see any AC to DC PSU's for them?...
...doesn't work :sigh: Here's the details (pasted from here) : I've set up as much as I can see is necessary, but I'm not seeing the blinking...
Hi there, I need a little help with part of a project I'm working on. On virtually every switch / hub I've seen, you get a green light appear on...
Ello ello :) I've been hovering around Bit-tech's project logs for a while now and I've been very impressed with so many of the mods here! So much...
I've just started a job in the worcestor / malvern area of the UK and I'm thinking of moving there. I'm not too fussy about where I live exactly,...
Don't you just love calling technical support? I've used Blueyonder Broadband at uni for like 3 or 4 years and had little or no problems with it,...
Okay, basically, I need some advice. I recently made some fairly basic LED Poi : [img] These are 4xsuper bright LEDs (in parallel) wired to...
