Im sure someone here has seen this before, but i just stumbled across it. http://www.riccibitti.com/tinyplanet/tiny_intro.htm A quick over...
I was wondering if anyone know where i could find an A/V switch that supports s-video and composite video with more than 6 or so inputs going out...
http://www.eng-tips.com/gviewthread.cfm/lev2/11/lev3/47/pid/237/qid/57678 http://www.allegromicro.com/press/p950118e.htm first two things...
sorry im so late, but ever heard of vacume forming? vinyl sheet is ideal for this method and almost any shape can be created up to and almost...
The usb to serial adaptor is a pretty interesting idea, i never thought about that, though then you go back to the driver issue, there arent any...
there was one in the Animatrix's gritty detective nior segment.
Simple question really. Could anyone give an overview of what would be involved in starting a project to offer schematics to allow someone to use...
Quick and Dirty http://dragonsden.emuunlim.com/ddkeytutl.htm just separate the controller card and run wires to switches. its not hard at...
most camping stores and army navy surplus places sell Mylar space blankets or emergency blankets, depending on the brand name.
Just out of curiousity, if IRdA is a different frequency couldent you take a standard remote and swap out an led that runs at the same frequency...
im pretty sure i have seen an ant farm before, those unoriginal *******s.
look for XMMS instead. same gui.
dont know why, but check your switch, what you are descrbing i almost exactily what happens if you put a on off switch on an ATX mb instead of the...
well, i ripped the monitor apart and blew out some dust, i looked about for any adjustment screws and the only thing i see is a hex bolt under a...
try man, id love to see it work, you could try taking an empty black ink cartridge out and taking a syringe, flushing it with solvent, make sure...
neat stuf but a projector mod i woiuld like o see is an adaptation using a cheaper bulb in an epson projector.
i would like to see that. where are the pics?
i just want the mouse...
I recently purcchased an old monitor at a thrift store for 6$, cant go wrong with that, right. I didnt expect much from it, pretty old, non...
i dont, but hey, to each his own
